I seem to be short one heater hose connection!
I have a 1975 350 in my 67 C10 that was a six. The original motor had a heater hose connection on the water pump but the V8 pump does not and was designed so one hose went to the radiator. I do have a connection on the manifold too. Is there a way I can use this pump and my original radiator. I am trying not to break the budget here. I put the V8 in the six position so I want to keep the long pump. I noticed that the V8 pump has a temp sending unit in it on top, could I put a heater hose fitting in there? How have others set this up? Any and all responses would be greatly appreciated and I'll buy the next round. Thanks. |
The V-8 pump does have a connection, you just have to take out the plug and install a nipple for the heater hose.
Randy70C-10:
I rechecked the pump and the only possible place for a heater hose connect would be the water temp sensor on top. Is this the plug you are talking about? Thanks. Pete |
![]() Join Date: Mar 2001
Yep, take out the temp sender (on top of the long style water pump) and use that port for the heater hose. If you can, there
may be a plug in one side of the head to you can use to insert the temp probe in. This is the way I had my motor, until I got a new 3-core radiator, I ordered it with the 5/8" nipple on the radiator.
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
Recovering Truck Driver
I'd pull the temp sender out of the waterpump and install your fitting there....and put the sender in the head where God intended it to be.
67 K-20 350, SM465, Eaton rear, 4.56 no spin option 00 Dodge 2500 4x4, 24V cummins, 5 speed Chad South Central Nebraska |
Keepin' It Stock
The other option is to have any local radiator shop install a heater return nipple in your radiator. I had this done recently - doesn't cost much.
72 Sierra Grande - Maych Forget about "do it right the first time". Do it wrong the first time to learn how, then do it right the second time. |
