07-01-2002, 03:07 PM | #1 |
wheel hop
Hey there,
When backing up an incline, I am getting quite a bit of wheel hop from rear. Would the fact that its lowered 6 inches cause this? I have yet to address the shock angle issue. I am planning on swapping and rotating lower shock mounts right to left for some added travel. Any ideas on whats causing the hop? Thanks, Tristen '71 C-10 |
07-01-2002, 04:04 PM | #2 |
Seņor Member
You hit it exactly. Your shocks are headed toward horizontal with that much of a drop. When you're backing up an incline, the rear of the truck has very little weight on it AND the shock has almost no leverage to push down the rearend. So... hop, hop.
Kenneth
07-01-2002, 04:31 PM | #3 |
Having shock travel shouldn't be a problem if you have drop shocks, its the angle thats really critical. Shocks need to be perpendicular to the ground, not parallel (sp.?)
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
07-06-2002, 05:28 PM | #4 |
there are some mods you can do to improve shock reaction such as unriveting and sliding upper shock stud brackets to right above the axle tube
ever notice that 73-up truck shocks mount one in front of and one behind the axle ? |
