07-01-2002, 04:14 PM | #1 |
Need engine ID'ed
The number on the front is V0110USC (in large numbers). It also has CD5776843 (in small numbers) on the front. Should be small block, poss 350, poss around 1980. Any help would be appreciated. Thanks, Cadpowered
07-01-2002, 04:26 PM | #2 |
Psycho-billy Member
look here...........
http://www.nastyz28.com/sbchevy/spcode9.html Looks like a 1983 350 truck motor. Use the "USC" part of the code to find the info.
'72 C-10 350 w/Lunati Voodoo cam (207*/213*, .437/.454), Performer intake, 625 Road Demon Jr. and Hooker headers. Support your community, support yourself. Buy local, buy American (or Canadian). Last edited by lux hauler; 07-01-2002 at 04:29 PM. |
07-01-2002, 04:45 PM | #3 |
Get the casting number off the block. That'll help in conbination with the numbers you already have.
The casting number will be on a small flat area behind the driver's side head. It's not facing the back of the vehicle (like on the back of the block) but instead is facing up. Where the bellhousing of the transmission bolts to the engine the engine is actually flanged out a bit. It's on the flange part. You should find something like: 3970010 I used some brake cleaner, a rag, a small shaving mirror, and a flashlight to see mine. Oil can sit on that flat area, and sludge it up. Good luck.
'69 3/4 ton C20 2wd-350ci/TH400 '69 3/4 ton Custom 20 2wd-350ci/4sp Manual '99 2wd 5.7 Chevy Tahoe Seattle, WA. |
