Old 09-07-2005, 07:37 AM   #1
mvpco
Cruise Control Pics installed
Hi All!
Any pics of Factory cruise control installed, especially the engine compartment? for 1972 I have some cruise master transducers and need to see placement on fender well.
Jeff Smith
Pensacola, FL
mvpco is offline   Reply With Quote
Old 09-07-2005, 11:09 AM   #2
72 longhorn BB
72 longhorn BB's Avatar
Mee too please
I have come accross some cruise parts, but am missing the transducer, and am strill wondering what is correct for installation.
I heard it was never factory installed, but there was a GM accessory kit which probably specified where to put the parts.
I have some pictures I collected of the parts ( lever, harness, etc) if you want to vieew them. Just let me know.
72 longhorn BB is offline   Reply With Quote
Old 09-07-2005, 11:25 AM   #3
chipflyer
chipflyer's Avatar
Here are part of the original install directions. I have another sheet at home that shows where to actually drill the holes I will post it tonight.
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 09-07-2005, 12:14 PM   #4
cwilkie
Chance
cwilkie's Avatar
Cruise
I have a complete cruise setup but not the instructions so please post more when you get time.
Chance
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
Old 09-07-2005, 01:04 PM   #5
72 longhorn BB
That's sooooooooo blink'in AWESOME!!!!!!!!!!!
Thanks SOOOOOO much for the diagrams. this will really help us. BTW - I have the stalk switch and the transducer, but I need a servo. can anyone tell me if they have a working spare to sell?
Old 09-07-2005, 01:42 PM   #6
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
I have one fatcory set-up on my 72 still on my truck...it's on a 402, but will that help?
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 09-07-2005, 03:08 PM   #7
edmonton72
Nothings as cool as my 72
edmonton72's Avatar
That looks to complicated, just put a brick on the gas pedal.
1972 C10 Longbox
In the middle of body off restoration
Rebuilt 355, turbo 400, 3.42 12-bolt
Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding.
edmonton72 is offline   Reply With Quote
Old 09-07-2005, 11:17 PM   #8
chipflyer
chipflyer's Avatar
Here are the rest of the install directions, happy to share them. Sorry for the crappy sized images, hopefully they will help.
Jeff
Old 10-09-2005, 04:59 AM   #9
72jimmycst
I just took one off my 72 marked "dana" could this be factory? The box with the speedo cables is more of a rectangle than in the pics but every thing else looked the same.
72jimmycst is offline   Reply With Quote
Old 10-09-2005, 09:56 AM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Do any of you have the speedo cable from the treansducer to the speedo head?
Old 10-09-2005, 01:47 PM   #11
RPOZ11
RPOZ11's Avatar
Cool
yes! its still assembled on my truck...did you need a pic of it?
HO72 build :
2017 SS
Old 10-09-2005, 07:43 PM   #12
72jimmycst
will this work?
Old 10-09-2005, 02:35 PM   #13
Longhorn Man
Well... actually I need one...I shoulda said that.
Old 10-09-2005, 06:11 PM   #14
Bob Moore
Dana
72Jimmy - I believe the units marked DANA are aftermarket. I have several of them on 73 & up trucks. I also see them on Chrysler Corp pickups and vans. I don't normally look at F*rds so I couldn't tell you about them.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 10-09-2005, 08:36 PM   #15
Longhorn Man
How long is it?
Also, can't tell from the pic, is one end smaller than the other? (the part that you spin on)
Old 10-09-2005, 08:48 PM   #16
RPOZ11
RPOZ11's Avatar
Question
LongHorn DUDE:
What is the direction on this that you are trying to achieve?
Do you need a cable?
so that you can find one in a yard or something????
HO72 build :
2017 SS
Old 10-09-2005, 09:27 PM   #17
72jimmycst
How long is it?
Yeah one end is appox 5/8" dia, the cable is about 4' long if it will work for you let me know just had it sitting around and no use to me. Do you have the gear indicator for a 72 tilt auto?
Old 10-09-2005, 09:31 PM   #18
Longhorn Man
Originally Posted by RPOZ11
If you need a cable, take a long cable out of a donot car, cut it down and angle cut the ends so that it feeds correctly into the back of the gear it is needed for....
I tried somethign like that, however, the ends are pressed into a square shape...I tried that, then tried to file it down...with no luck.
OK, time for me to look dumb... is that 4 inches, or 4 feet? (I always get that confused) Either way, I think I need one more like 2 feet.
Old 10-09-2005, 11:51 PM   #19
72jimmycst
4 feet, did you say that the servo end was square? this cable is out of a 72 jimmy still have all the parts but I think it's era correct aftermarket since it's marked "dana".
Old 10-09-2005, 08:52 PM   #20
Longhorn Man
No, I need one for my truck.
The short cable on mine snapped a couple weeks ago at the begining of a road trip.
Old 10-09-2005, 09:20 PM   #21
RPOZ11
RPOZ11's Avatar
is it the cable you need? or is the jacket housing broken too?
HO72 build :
2017 SS
Old 10-09-2005, 09:23 PM   #22
RPOZ11
RPOZ11's Avatar
If you need a cable, take a long cable out of a donor car, cut it down and angle cut the ends so that it feeds correctly into the back of the gear it is needed for....
HO72 build :
2017 SS
Old 10-09-2005, 09:54 PM   #23
RPOZ11
RPOZ11's Avatar
That process is called Swedging!
Most likely these were hydraulically pressed on a machine to square that up from the round cable shape to this sqaure shape!
Throttle cable places that repop Camaro stuff can do this for you! And...This ain't cheap! Sorry!
HO72 build :
2017 SS
Old 10-09-2005, 10:35 PM   #24
Longhorn Man
I kinda figured it was a press that did this. Even so, I tried using a shop press, vice grips, even a hammer.
Yeah, i still need a cable.
I thought I hit the jack pot in the junk yard, I found a later model speedo cable, with a plastic end cap on the cable. it looked like it was placed on a predetermined cut to length cable. I grabbed this, and figured i could simply pop the end off of the cable, cut to the length I needed, and glue it back on.
Nope. That didn't work either.
Old 10-09-2005, 11:52 PM   #25
Longhorn Man
Both ends of the cable were square. I'm talkin the cable it's self, not the housing.Just like the one you pictured...
Tomorow, i'll look at mine and see if I am mistaken on cable length...and see if there is a way I could use a 4 footer if mine was shorter.
What would you want for that?
