Old 09-08-2005, 10:27 AM   #1
rivernut
73-87 seat conversion?
Can a bench seat from an 81 GMC 4wd fit right into my 72 2wd. I hate to take it out (its in a junkyard) if It won't bolt right in. Or can it be modified easily. Thanks
Rivernut
'72 1/2 ton 350 auto
rivernut is offline   Reply With Quote
Old 09-08-2005, 10:35 AM   #2
stllookn
Saving 1 truck at a time!
stllookn's Avatar
It takes mods with a torch and a welder to get them to bolt into the 67-72 holes and sit at the proper height. I don't know if the entire 67-72 slider assembly will bolt onto the base of the 73-87 seat...it was easier for me to just weld additional pads onto the modified 73-87 sliders.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 09-08-2005, 07:16 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
The floor in a 73 - 87 is no where near being flat. Onless it'll bolt onto your 72's track, it will not be anything close to a simple bolt in.
Old 09-08-2005, 07:26 PM   #4
hilljob26
hilljob26's Avatar
you could always just drill new holes in the floor
21 2500hd duramax
58 apache
HILLJOB GRAPHIX--for all your graphic needs
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=542497
LS ENGINE SWAP INFORMATION THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=377348
4l60 to an NP205
http://67-72chevytrucks.com/vboard/s...43#post3697343
hilljob26 is offline   Reply With Quote
Old 09-08-2005, 10:13 PM   #5
rivernut
Thanks guys,
I think I am going to take it out and find out just how much screwing around I have to do. It only cost 15 bucks and is worth my time to see how much modifying I have to do. I own a welder, so it's no big deal.
Rivernut
Old 09-09-2005, 12:59 AM   #6
qksilver
If you drill new holes make sure you use a renforcement plate on each one. Other wise the bracket could rip out the floor
qksilver is offline   Reply With Quote
Old 09-09-2005, 02:34 AM   #7
stllookn
stllookn's Avatar
No need to drill new holes...just make these four pads and drill them to fit the 67-72 seat holes, heat the mounts on the 73-87 seat and bend them down so they are 90 degrees to the bottom of the seat, then weld them to the flat pads. Here is a shot of the drivers side rear of the seat that I finished a while back.
