Old 09-10-2005, 04:19 PM   #1
longhorn71
longhorn71's Avatar
Blazer is headed for paint!!!
finally got the blazer sent to my buddies place for paint!!!His shop has been so busy he was a month behind but now he has the time to look at it.It should be done around the 1 of oct.The only pic i have of it is the one in my advatar.In the picture it looks good but the two tone jod is real bad.One side the sliver is not straight!!And the top was in bad shape as well.It had some rust problems along the bottom too,
longhorn71 is offline   Reply With Quote
Old 09-10-2005, 04:27 PM   #2
longhorn71
longhorn71's Avatar
Here are some before pics.........
Old 09-10-2005, 08:45 PM   #3
Big Block
Big Block
Big Block's Avatar
How much drop is on your Blazer? Did you use drop spindles and drop springs up front? What did you use to drop the back and how much? I want to drop my 80 2wd Blazer. Thank's B.B.
Big Block is offline   Reply With Quote
Old 09-10-2005, 10:10 PM   #4
longhorn71
longhorn71's Avatar
it has 2" lowering spindles and stock springs in front.A 2" droppoed shakle kit in the rear.I am gonna replace the back set up with an axle flip kit tho.The passager side spring end almost touchs the feul filler hose now
Old 09-11-2005, 06:31 PM   #5
Big Block
Big Block
Big Block's Avatar
I have never lowered a leaf spring truck. I have never look at a axle flip kit. How does it work? I know the axle is now mounted out side the springs , and you relocate it under the springs. But how do the spring perches work now that they are on top of the axle? Thanks B.B. PS I like the front end height on your Blazer.
Old 09-12-2005, 01:27 AM   #6
longhorn71
longhorn71's Avatar
there is a special brakets for the flip kit and i am not sure if it needs to be welded in or not
Old 09-12-2005, 10:59 AM   #7
a28doc
'87 V20 4x4
a28doc's Avatar
def post pics when you get it back to keep us updated on the progress
Doc
'86 K5 Blazer 4x4 FOR SALE
'87 v20 4X4
'99 S10 Blazer 4X4
a28doc is offline   Reply With Quote
