Junior Member
![]() Join Date: Dec 2003
lever on rear diff?
I just got a 86 3/4 ton burb and I went to go replace the hard brake line going to the rear and it goes into a junction that looks like it controls a lever going to the rear diff. Can someone tell me what that lever going to the rear diff may be.
junk collector
load based proportioning valve- not the thechnical term, but you know what i mean
lets more brake line pressure to rear if there is a load
'87/89/76 K5 in progress '99 K2500 short crew '91 camaro rs '98 jeep tj '52 willys cj3a |
user # 2756
![]() Join Date: Jun 2001
I was going to ask the same thing! It's on my 89 3/4 ton burb. Is this part of a "towing" package? My burb has a power steering cooler, oil cooler, tranny cooler, TH400, 4.10 gears.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs 1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX 1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears 1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now..... 1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone. 1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed. 1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm ![]() |
Junior Member
Mine also has the th400 with the tranny cooler not sure about the other things mentioned. I was told though that it did have the factory tow package. Thanks guys!
junk collector
not sure of the tow package question, but many compact trucks have this also. I had a 2wd base model mitsubishi that had it and my k2500hd has it too, it might vary by manufacturer as to whether or not these were installed.
