Old 09-17-2005, 03:39 PM   #1
torquepower
71 GMC 3500 longhorn cooling problems 454
Hi there, I'm new here. Looks like a very nice board with lots of interesting trucks, people and info.
Just bought a 1971 GMC, sierra grande, 3500, longhorn TH400, eaton rear 4.10, no air, 454 (will fry the tires at will, even rolling) The 454 looks like its from an 88, with 88 long water pump and pulleys and alternator, it also has an edelbrock performer manifold, HEI.
The truck has a 5 bladed fan with really big pitch that sounds like a jet engine when get going over 25mph, after driving for a while your ears start buzz, I'd like to get a clutch and change the fan to a 7 blade 18" diameter, but the shortest one I've seen in the wreckers (consistent with hayden 2705) only leaves about 1/4" clearance to the rad. That seems awfully close. The truck is missing the fan shroud. I'm trying to find out what parts I need to make it work.
Questions;
1> Did these come with short or long pump?
2> Is the BB fan shroud different from others?
3> Where is a good source for pulleys and brackets? The old stuff is rare around here. Are AC setups different on the pump and crank pulleys then non AC units.
4> I have a power steering pump with remote res, is this stock? What is the res attached to stock?
5> What side is the alternator supposed to be on, mines's on the passenger side.
Any help would be appreciated. Thanks.
torquepower is offline   Reply With Quote
Old 09-18-2005, 03:09 AM   #2
dyingdeadman
dyingdeadman's Avatar
i can answer a couple of these questions, the bb shroud is differnt i think but not sure of the difference. the power stearing pump with remote res. is stock and the alternator is on the passanger side for non a/c and on the drivers side with a/c, well that goes for the older big blocks anyway. not sure about the newer ones.oh and you can probely get pully's and brackets from just about any junk yard for your 454.
hope this helps some and welcome to the board.
72 GMC sierra 3/4 ton 402 bb
68 GMC 3/4 ton
2010 camaro rs: daily driver
dyingdeadman is offline   Reply With Quote
Old 09-18-2005, 03:30 AM   #3
longhorn71
longhorn71's Avatar
welcome to the board!!!glad to see another canadian longhorn
longhorn71 is offline   Reply With Quote
Old 09-19-2005, 12:39 AM   #4
tomatocity
tomatocity's Avatar
Welcome to the Board.
In my research for a shroud I thought the BB shroud was deeper than a SB. Yours looks very close to the front of the engine bay. Don't BB usually sit closer to the firewall than a SB? Looks like a SB shroud would not fit that setup. Was this truck always a BB? Wish I had a BB so I could send you some pictures. A shroud and clutch fan would help your overheating problems and reduce the noise and increase the power. An electric fan would be an excellent solution.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 09-19-2005, 01:02 AM   #5
RPOZ11
72 BB C30 Super LongHorn
RPOZ11's Avatar
Cool Image
Hope this helps you...it was late, it was the best I could do...
72 BB C/30 Longhorn Super
HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM
HO72 build :
http://67-72chevytrucks.com/vboard/s...d.php?t=714492
2017 SS
RPOZ11 is offline   Reply With Quote
Old 09-19-2005, 03:23 AM   #6
Americanrider
Read post #6 on this thread.... yea, I know you want stock or close to it but the line has been crossed when the '88 454/hei/performer went in and the 402 went bye-bye. In the long run you might be spending a few less loonies per liter.
http://67-72chevytrucks.com/vboard/s...1&page=1&pp=25
Americanrider is offline   Reply With Quote
Old 09-19-2005, 05:17 AM   #7
torquepower
Total fluke. I've found the original owner, he has the original 402 with all the accesories and shroud. I can make it a matching # truck.
I bought this truck from the paper, the guy who sold it to me never transfered ownership, I recognized the name on the registration of someone I met once at the racetrack over 5 years ago. Tracked them down through a friend of a friend.
Who ever said having a short memory is a blessed thing.
Thanks for all your help.
Old 09-18-2005, 04:11 AM   #8
Americanrider
Northern Neighbor
That is a tight fit! Have you considered losing the fan and going to a Electric pusher setup? Might gain a couple of horses (not that you need them) but it will save your hearing.
Old 09-18-2005, 04:21 AM   #9
torquepower
Originally Posted by Americanrider
Northern Neighbor
I'd like to keep near stock as best as possible, I'll go electric as a last resort. I used to use electric fans on my oval track stock car and found that mechanical fans worked best.
Old 09-18-2005, 11:31 PM   #10
Bob Moore
The 68/72 BB trucks came with short waterpumps. For trucks this means alternator on driver side and A/C compressor on passenger side. Special brackets and pulleys are necessary to convert from long pump. The brackets and pulleys are available just somewhat expensive - a complete set will be $500 plus. It also takes power steering brackets to finish the job.
The big block fan shroud is beefier than the small block - I don't know if the SB shroud will work or not - probably will but not positive.
You will have to ask yourself is the noise reduction worth the $$$
Good luck - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 09-19-2005, 12:23 AM   #11
acloco
Get rid of the fan....and install an electric...with a thermal switch.
acloco is offline   Reply With Quote
Old 09-19-2005, 05:20 AM   #12
krue
Designated A-hole!
krue's Avatar
Congrats on the find. Lucky dog.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 09-19-2005, 12:08 PM   #13
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
Welcome To The Board! Great Truck and that's awesome that you were able to track down the original 402!
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
