09-19-2005, 11:34 PM | #1 |
Questionable
How to remove front clip?
tried to install the LS1 tonight. tight garage space and interesting setup (load balancer getting in the way) is causing problems.
I need to remove my front clip while keeping the fenders and inner fenders on. What is the easiest way to do this safely? I know I can just get in and remove bolts, but I want advice and tips on how to do it right without worrying about having to realign everything later. Thanks.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
09-20-2005, 12:30 AM | #2 |
TOTY 2006
Are you talking about removing just the grill and radiator core support leaving the fenders in place, or removing the entire front clip?
If front clip, remove cowl, then you have two upper bolts and one lower bolt to remove per fender where it meets the cab. (watch for shims, and label them so you can re-assemble) There is one more bolt thru the inside of each inner fender to the cab to remove. Moving to the front, you have the two bolts for the radiator support. there may be a bracket on the driver side inner fender that needs to be removed. Other then that, the rest is wiring (unplug it at firewall), then two to four people (two "I feel strong" types, or four "I just came for the beer" types) to help lift it and walk it off. Note, the two radiator support bolts will give you trouble lifting the clip if you don't remove the bolts. I keep forgetting to pull them out :duh: Just curious, "How much clearance do you need?" Could you just use the hoist (without the load balancer,) to set the motor in place temporarily, then pick it back up with the balancer connected? Of course, this is assuming that you are using a normal engine hoist, but your "interesting setup" comment has me wondering..... Last edited by John Fabris; 09-20-2005 at 12:47 AM. |
09-20-2005, 12:56 AM | #3 | ||
Questionable
I have the bumper and hood latch off, I just want to remove the piece holding the headlights and the grille. I'd like to take it off in one piece if possible. This is what I'm looking for tips on how to do easily so I don't putter around and take out five million bolts, then spend longer than it takes to put the engine/tranny in to actually get it back together. Quote:
09-20-2005, 09:38 AM | #4 | |
More Cowbell....
There once was a member from Puckett.....Who ( fill in the blank blank blank ) bucket |
09-20-2005, 01:51 AM | #5 |
Questionable
Okay, look...here's the deal. I'll write above each picture so you understand what the problem is.
I have a garage. It's not too tall and it's not very deep. If there wasn't an inclined driveway with a ditch about 1.5 carlengths away right outside the door, I'd do it out there. The garage has two stories of house above it or I'd make it bigger. Look at this first picture of my sticking the engine + tranny in by myself in the garage. Note these things: FIRST: I got the engine to the point that the oil filter was sitting on top of the engine tower. This doesn't show in the pictures. I understand I need to drop, tilt, drop, tilt. I've tried every conceivable way of making this go in, believe me. Now, in the first picture below I'm using the 1 ton boom setting because if I go to ½ton, the arm of the hoist smacks into my garage door lift. Also, notice the proximity (the red lines) to the garage door itself. If I use the ½ ton setting, the hoist is eating into the door. If I open the door with the ½ ton setting, it's even closer thant the garage door lift, so I can't get the engine high enough to go in. So, I had to go with 1 ton arm position and lift to high hell. From a geometric standpoint, it looked and felt possible to me. Scraped my painted bumper a bit, but it needs a repaint anyway. I can't roll the truck out the door because it would take 5 musclebound arnold scwarzennegars (sp?) to push it back up the gradient out there garage because of the incline. Now, here's the real deal. Because of the extreme angle with the 1ton setting you see below, when I try to get that lovely ECE GenIII motor mount down to its receiving piece to measure it up, this requires some swift maneuvering. I managed to get it within 5 inches, but the load leveller screwed me because the stupid handle and chains were smacking into the firewall, so it was physically impossible to make it work. I can't flip the load leveler handle the other way - if I do, the crank smacks into the hoist arm and I can't level the damned thing out. So, you see, I'm suffering from too small of a space and, if I can manage to use the ½ton setting and remove the grille, bumper and front headlight thing, I can do the job.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 09-20-2005 at 10:13 AM. |
09-20-2005, 02:03 AM | #6 |
what about if you jack up the front of the truck and push it a few inches over to clear the door opener track then you can extend the boom out on the crane. also if you tilted the engine a bit more from where its at now you could jack up the front of the truck and give yourself room to drop the motor in almost vertical and get it farther down cuz the floor wont be so close and interfere with the tail shaft. the level out the engine and get it to sit it belongs and put your bolts in the engine mounts
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. Last edited by cableguy0; 09-20-2005 at 02:13 AM. |
09-20-2005, 02:15 AM | #7 | |
Questionable
I looked at the grille and radiator support. There's about 2 dozen bolts holding the damned thing in and I got a goot amount of rust all through the rad support. Grille is ok. This would be a good time to replace it also. :\ Man, I did not want to spend more money on this thing yet. I need to make it a daily driver before I can afford that...gotta get this damned thing in. So, there's no way at all to remove the grille and rad support in one piece by taking off just a couple of bolts?
09-20-2005, 02:16 AM | #8 |
Questionable
PS - I just saw your edit. I only have one floor jack and no bottle jacks. That's a good idea, but i'll need the floor jack to lift the tranny up because there's no xmember in there right now.
09-20-2005, 02:17 AM | #9 |
use the leveler to get the tranny up.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
09-20-2005, 02:18 AM | #10 |
Questionable
good point. hmmm, ok, so i have two options.
take off the grille and rad support and know i can do it first time with no problems, or take a risky shot at attempt #2, fight to get it in only to measure up the mounts, pull it back out again, drill the mounts, then fight to get it in again. which would you choose?
09-20-2005, 02:20 AM | #11 |
probably option 2 i aint never been known to take the easy way out. besides when its in you can always just lift it up a bit to drill the holes in the mounts. if you cant tell i hate realigning body panels. its a time consuming pain in the @ss and im impatient
09-20-2005, 02:23 AM | #12 |
besides it will fall into place once u jack the truck up and your gonna kick yourself for not thinking about it
09-20-2005, 09:10 AM | #13 |
the problem i see is that you dont have the arm of the motor hoist extended far enough out// if u extend the arm out to the longest you'll be able to get it in by lowering the engine a bit then tiltilin the tranny up then push engine back lower a few inches lift tranny some more push engine back lower engine lift tranny push back// it's done just an inch or 2 at a time /// the way you've got the engine hoist now it won't get the engine back to the proper position
09-20-2005, 10:09 AM | #14 | |
Questionable
Sorry Putter, meant to say sputter.
I had a chance to tinker with your option this morning with one of my friends and we didn't have much more luck. I'm going to try one last time with the load leveler flipped the other way, but if I try the third time and this doesn't work, I'll be pissed. How hard is it just to remove the rad support and grille? I can't believe that it would be worse than what I'm dealing with right now. (maybe more time consuming, but ...)
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 09-20-2005 at 10:11 AM. |
09-20-2005, 10:12 AM | #15 |
why not take the WHOLE front clip off?
It's like 8 bolts? If you mark the shims' location, you'll have the panels back on. Makes it way easier to do the exhaust and motor mounts. |
09-20-2005, 10:25 AM | #16 | |
Resident Curmudgeon
Pulling the front clip as a whole unit has always been easier for me that trying to wrestle, bull and jamb.. Once the wiper and cowl is off, it's < 20 bolts and with 3 or 4 guys it's easy to take off. Plus you already have the wiring harnesses removed. You should have done it before removing hood for 2 reasons; 1 - you don't have to realign hood, and 2 - It stengthens the clip by keeping everything aligned when lifting off. Realigning the whole clip as a unit is easy, far easier than realigning the hood by itself IMO I'll never understand the mentality that does not see this as the path of least resistance. It's a 1/2 hr R&R and that time will repay itself 10 fold in ease of access for mounts, exhaust, accessories, etc
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
09-21-2005, 01:36 PM | #17 | |
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck. |
09-21-2005, 02:07 PM | #18 | |
Questionable
Save any body shims you find. Mark where they went so you can lineup parts in the future. Remove the bumper: This takes 6 bolts only. A couple can stay in. Remove the cowl: Take off both wipers, take off bolt near the hood and behind the top of the door on each side, remove all screws and antenna from the top of the cowl (and the screws where the rubber flap/weather seal is if you still have one) and it should lift up easy. Remove the outer fender bolts: two are up top close to the door. One is at the bottom of the fender close to the door. There is one more bolt just up and under that last one, you'll need to get under the truck and look in to see it - it has a big washer on it (mine did). it's about 2-3" above the bottom lip of the outer fender under the door, don't confuse it with the rocker panel bolt. Remove the inner fender bolt: Look inside the wheel well for the bolt. Unbolt the radiator support: This is done with two bolts that sit just under radiator - they have a smooth head and the bolt is under the truck. It's about as big around as your thumb in diameter, think it's an 11/16" nut. There might be a bracket with 4 bolts where the steering column goes through the inner fender (driver's side). These will need to be undone. If you can't lift one side easily, try to find the holdup. I'm pretty sure that's all of them though. BAG YOUR BOLTS AND LABEL!
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. Last edited by shifty; 09-21-2005 at 02:08 PM. |
09-21-2005, 07:22 PM | #19 | |
09-20-2005, 10:17 AM | #20 |
Questionable
Good point, Grendel. Maybe I'll just do that. I gotta think about exhaust and other stuff. Should help with wiring also.
I just couldn't believe there's not some easier way to take off the grille and rad support. I'll take Fabris' info above and go check it out.
09-20-2005, 11:04 AM | #21 | |
09-20-2005, 11:24 AM | #22 | |
Resident Curmudgeon
As far as setting that thing down, if the rust is bad enough to crush under the clip's weight, then you need to fix it anyway. I personally would protect the edges on the door end of the fenders to prevent paint chips and set it upright against a wall to keep it out of the way.
09-20-2005, 11:36 AM | #23 | |
The longest time was spent talking about snapping turtles... Also took a bit of time to get a booty-fab alt bracket off so I could get at the lower radiator hose. Got to love Yankee Ingenuity. Last edited by FormerMember; 09-20-2005 at 12:04 PM. |
09-20-2005, 02:04 PM | #24 | |
Questionable
Thanks for chipping in guys. I tried the 1/2 ton setting and I was having a pain in the ass time getting around the support rails for the garage door and the center support/chain. I give up :\
09-20-2005, 11:26 AM | #25 |
Saving 1 truck at a time!
Shifty, Just lay it directly on the ground...no problem. It will lay on the lower portion of the fenders that are already dirty and scratched from road gravel...however your truck looks pretty nice. You might just put some corrugated board or rags on the ground to avoid scratching the paint.
BTW...nice truck!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
