Old 09-21-2005, 02:23 PM   #1
AK|Bandit
AK|Bandit's Avatar
Got the big block in my '72 K5
Getting ready to fit the engine for clearance
Engine centered over the motor mounts
Driver's side firewall before the beating
...and after
I notched a little piece of the frame to add clearance to the PS pump and pulley...It cleared okay before I notched it, but I figured what the heck.
The distributor cleared fine without any beating...thanks to the 3in body lift.
Oil pan clearance wasnt even an issue with the stock crossmember. I used the small block mounts.
And this is how it sits right now...
After I fit the engine for clearance, I attached the tranny and slid it in as one piece. This made for a very easy install.
I still have to fit the headers in, but it looks pretty tight I'll update when I get them in...if they fit...
The passenger side firewall required minimal "massaging" to fit the valve cover.
I cant wait to fire this bad boy up!
It's better to wear out than rust out!
AK|Bandit is offline   Reply With Quote
Old 09-21-2005, 02:28 PM   #2
Yukon Jack
Yukon Jack's Avatar
A man and his big block . . . what a beautiful thing!!!!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 09-21-2005, 05:59 PM   #3
charlieo
Very purdy , purdy indeed !! I wish it was mine .
charlieo is offline   Reply With Quote
Old 09-21-2005, 09:54 PM   #4
67cst
i love summertime
67cst's Avatar
so you can use sb motor mounts on a bb? i got a 454 th400 for the 71 and im going to do the same thing here and i thought id need bb mounts forsure
1967 shortbox stepside Chevy, 365 hp 327, th400.
GLOVE BOX LIGHTS FORSALE, click link for info
http://67-72chevytrucks.com/vboard/s...d.php?t=273724
67cst is offline   Reply With Quote
Old 09-22-2005, 12:57 AM   #5
AK|Bandit
AK|Bandit's Avatar
Yep you sure can. I went to the local parts store here and asked for '72 K5 motor mounts for a small block 350. They were only about $25 for both sides and they fit without any modification. Bolt holes lined right up.
Old 09-24-2005, 01:25 AM   #6
4x4Poet
I'm pretty sure the whole bb motor mounts thing is for 2wds. 2wd BBC swappers have hassles with either using scarce, expensive eng xmember towers with inexpensive motor mounts, or using plentiful eng xmember towers with expensive motor mounts. That's my understanding from perusing the board, anyway.
'71 GMC K20 Suburban, '71 GMC K10 Suburban, '72 Chevy C10 CST Suburban, '72 Chevy K20 clunker pickup.
4x4Poet is offline   Reply With Quote
