Old 09-22-2005, 12:13 AM   #1
Rooster's 67
Rooster's 67's Avatar
watts link
anyone know where I can get a watts link kit?
The problem with America is stupidity. I'm not saying there should be a capital punishment for stupidity, but why don't we just take the safety labels off of everything and let the problem solve itself?
Rooster's 67 is offline   Reply With Quote
Old 09-22-2005, 12:46 AM   #2
Musclerodz
Try these places.
http://www.speedwaymotors.com/
http://www.stockcarproducts.com/index.html
http://www.allstarperformance.com/
http://www.aa-mfg.com/index.html
http://racecareng.com/
Mike
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 09-22-2005, 01:01 AM   #3
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
watts
ALSO CHECK THESE GUYS OUT, THERE KITS LOOK AWESOME AND WORK GREAT !
BARNYARD CUSTOMS WATTS LINK
eww I sound like I work there
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 09-22-2005, 01:56 AM   #4
Jaredm82
Active Member
Jaredm82's Avatar
www.totallypolished.com
Jaredm82 is offline   Reply With Quote
Old 09-24-2005, 04:40 AM   #5
BK
BK Built
BK's Avatar
Totally Polished watts link = $500
Speedway motors watts link = $70
not that the TP watts link is totally bad ass, but its alot of bling and alot of money. i modded my speedway watts link and it works great, 19" of lift and only moves 1/4" from center. plus, when your layed out, no one sees it.
BK is offline   Reply With Quote
Old 09-24-2005, 10:04 PM   #6
el curioso
el curioso's Avatar
Sorry for Jacking.
But it's related : When mountin the bars in a watts do they have to be parallel 100%?
ON the Speedway motors link do you have to mod the bars or just weld in ?
el curioso is offline   Reply With Quote
Old 09-25-2005, 05:14 PM   #7
DM310
I have the speedway kit and had to cut the arms down a little
66 C10 (under construction)
1.5" crossmember drop
2" Z'ed frame
8" rear notch
Watts-link
Bagged
DJM 3" spindles
DM310 is offline   Reply With Quote
Old 09-26-2005, 03:43 AM   #8
BK
BK Built
BK's Avatar
you really should have them as close to parallel as you can... but it doesnt have to be 100%. If you want to, make it so that the top bar extends OVER the pivot, as to give more travel. The speedway bars you need to cut, they stick about 2" out each side of the frame. I shortened mine 3" each and re-threaded them(make sure you cut off the right handed threaded side, if not... good luck finding a left handed tap) and it worked great. 19" of lift and only goes 1/4" off center.
Old 09-26-2005, 06:31 PM   #9
johnnyrockets187
hey DM310, did u make the support brace that goes on the axle housing or did you buy it from another company?
johnnyrockets187 is offline   Reply With Quote
Old 09-26-2005, 07:03 PM   #10
BK
BK Built
BK's Avatar
he made the brace. i also made my brace, it just follows the curve of the diff cover, the kit is designed to bolt through the diff cover, but its also designed for F*ord 9" rears which you could, but mine just goes over the diff and bolts 3 bolts top 3 bolts bottom to the diff cover.
Old 09-26-2005, 07:30 PM   #11
johnnyrockets187
is there any way you could get a few pics of your support bracket?, id lke to see your design
Old 09-27-2005, 02:08 AM   #12
BK
BK Built
BK's Avatar
i wish i could get some pics, ill try to get a friend to take some though. the panel is 8 hrs away burnt to the ground sitting in our lot, good thing is the floor out back burnt out so its easy to see it all. ill try to get some pics.
