Old 09-24-2005, 12:59 PM   #1
matthufham
bed too high after new cab bushings?
i finally got the cab done, and i put my new poly cab bushings from gmc pauls on, and got the bed on, now the bed sits too high? what's the deal? here's pics.
matthufham is offline   Reply With Quote
Old 09-24-2005, 01:07 PM   #2
cdowns
cdowns's Avatar
are you sure you put them in the right order if i remember there's a definate front and rear differance//and did you have the proper original metal washers needed for proper install??
Old 09-24-2005, 01:49 PM   #3
lost wages
lost wages's Avatar
mine did the same, i had to shim mine to look right. I tryed moving all the cab mounts to different spots but it didnt help.
lost wages is offline   Reply With Quote
Old 09-24-2005, 02:12 PM   #4
72MARIO
72MARIO's Avatar
You need to shim the cab mount there should be square shims included in the cab mount kit. I had to shim my cab and box to get the lines perfect.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 09-24-2005, 02:29 PM   #5
Maximum Overdrive
December 21, 2012
I dont know---that looks like an aweful lot of shims needed to make up the difference. Looks to be at least a inch or so off.
"!Ama Sua, Ama Kjella, Ama Lllulla!"
Maximum Overdrive is offline   Reply With Quote
Old 09-24-2005, 05:36 PM   #6
matthufham
i didn't get any shims, and the fronts are noticably different from the rears so i got them in the right place... i'm going to see if i can make washer magic, i'll be back later with results.
