09-25-2005, 05:37 PM | #1 |
72 BB C30 Super LongHorn
Today's accomplishment
Got the front frame tore down to this. I will begin with removing the ball joints and strip the a-arms down to be powder coated or imron Black painted....Might as well do the same to this lower X-member...
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS |
09-25-2005, 05:40 PM | #2 |
GM Spring Decals
Here is one of the original front coil spring decal stickers for a C/20 402 T-400 with A/C P/S Disc Brakes and 16.5" rims. This truck was also originally a Custom Camper edition. In my Camaro ID'ing, the more the options and weight class etc, the front springs decal ID's and part #s will change. So, this is the correct Decal ID GM part # from this application!
09-25-2005, 05:46 PM | #3 |
GM Front Spindle Paint
Got these off today and found the asembly line paint swipe on the backside of the upper section of the spindle.
It appears as such: White paint dabbed first, the a baby blue color over the top of that one. I looked the lower portion of the spindle and there was none of this there. I assume, for resto purposes, that the white was for the first torque securing ID'ing, and the blue was for the 2nd securing. I am sure this was done so that the final check off of all safety items were checked off! This application is from the same truck above: C/20 402/T-400 Custom Camper front Disc Brakes...
09-25-2005, 05:57 PM | #4 |
GM Shocks
Are these original???
Same truck: C/20 CC 402 A/C etc etc They are stamped GM, with the part # of 4974666; both L/R shocks have the same #s on them. I will post all the #s off the bottom of these as I can... It also says: 072-86-1
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS Last edited by RPOZ11; 09-25-2005 at 06:01 PM. |
09-25-2005, 06:44 PM | #5 |
man you're getting a lot of work done dude! Hey do you still want the front A arms and stuff? I've been having trouble finding a box big enough to fit it all in. you know, the ones I have are actually rusted worse than the ones you already have. they were covered in caked mud and stuff and it really screwed 'em up, but with a drill, a wire wheel, and a couple hours work they'd be OK.
RJD 1984 Chevrolet C30 welding truck 454/SM465 1977 GMC C15 pickup 350/TH350 1970 Chevrolet C20 pickup 350/TH400 1970 Chevrolet K20 Suburban 454/TH350 1969 GMC 8500 478M V6/5 spd winch truck |
09-25-2005, 06:55 PM | #6 |
Well, I was interested in them but I now have these off. I was looking at redoing a set to have ready for install but I see I have more work than I need currently!
I will let them pass; although I'd like to have them, I agree that costs and boxing may be taxing on all of this!
09-25-2005, 06:58 PM | #7 |
Actually, I am leaning towards repainting the entire frame; Im this far!
I dont know how to paint but the frame would be a great test bed for my learning! Anybody offer me any suggestions on repainting the frame myself? Never painted before! I would desire that Imron Black as it would be tough for useage! I do have local access to a chem strip facility so I could have it all stripped to a non-rustyed phosphate finish for paint... Thoughts anyone???
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS Last edited by RPOZ11; 09-25-2005 at 06:58 PM. |
09-25-2005, 07:04 PM | #8 |
On my Longhorn, is there any way to tell the rear axle gears from the outside besides spinning the wheels/pinion?
Was a Posi ever available for these? I believe that this is an Eaton rear axle with the slide out ring/pinion center section alike a Ford 9"
72 BB C/30 Longhorn Super HO72 No-Spin, #'s matching, Tilt, Tach, AC, AM/FM HO72 build : http://67-72chevytrucks.com/vboard/s...d.php?t=714492 2017 SS Last edited by RPOZ11; 09-25-2005 at 07:05 PM. |
