10-02-2005, 10:43 PM | #1 |
16" wheels for '69?
Just wondering: my '69 GMC with drum/drum brakes and 6-lug wheels are running 15" tires now...will late-model 16" wheels fit the old pattern and will their offset give me clearance around the coil suspension? Thanks, Bud
10-02-2005, 10:48 PM | #2 |
senior member
i think the only problem you might run into is the hole in the middle might be too small
69 GMC bagged |
10-02-2005, 10:48 PM | #3 |
from what i hear, there is something different that wont work right with newer style rims....i wanted to get some too, but people said they wouldnt fit
-Steve |
10-03-2005, 01:34 AM | #4 |
Gone Fishing
The only real problem is the center hub hole is too small. You would have to waller it out a little bit to work.
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
10-03-2005, 09:34 AM | #5 |
Front hubs are too large. You will have to take the wheels to a machine shop to have the hole enlarged. I have a set off of a 03 Suburban. Where are you located?
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
10-03-2005, 09:43 AM | #6 |
Offset is wrong..
Hole is too small Your wheels(if aluminum) will rub on the control arm. Trust me been there.
2006 Titan SE Crew Cab Daily Driver 2005 Mazda Tribute (Wifes car) 1969 C10 SWB 350/3 Fleet "Max" 1969 Chevelle 2 door 350/3 |
10-09-2005, 10:44 PM | #7 |
Rob, I'm in Satsuma, AL, just north of Mobile, AL...is it much trouble to enlarge the holes with a some sort of grinder wheel? I also had someone at a local salvage yard say that they thought some aftermarket Isuzu wheels would fit. Thanks, Bud
10-10-2005, 09:12 AM | #8 |
Bud,
You only have to enlarge the 2 front wheels (all 4 if you wanted to rotate them). You would have to be very careful doing them yourself, I would suggest getting a quote from a machine shop first. Let me know. Rob
10-10-2005, 11:26 AM | #9 |
I am not able to figure out if you guys are talking aluminum or steel wheels. I had the centers of a set of steel wheels enlarged by a machine shop for 15 bucks a rim, just to let you know.
67 short wide 355ci 3 on tree 69 short wide 250ci 3 on tree 68 long wide 283 3 on tree 72 2wd Blazer project 454 5 speed |
10-10-2005, 12:39 PM | #10 |
Aluminum wheels like these.
