Old 10-05-2005, 10:35 PM   #1
BubbaGreen
OEM/STOCK hi-press power steering hose part number needed.
Folks, I have installed a ramjet-350 w/serpentine belt system...have tried a couple different AC_Delco power steering hoses and nothing is aligning up correctly. This is a 71 2wd swb...
I am asking if anyone has a good part number that they have tried and it works. This serpentine system puts the P/S pump in almost the same position as the stock v-grove system. FYI: I am using the original type of fittings (inverted flare, not the newer saginaw metric type)
If anyone has pics, that would be even better. If I cant find a suitable replacement, will end up have some made, but...would much prefer an off the shelf part.
THANX in advance
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi
See it at www.prismnet.com/~grzanich
BubbaGreen is offline   Reply With Quote
Old 10-06-2005, 12:06 AM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I don't understand why you can't use the stock hose if the pump is in pretty much the same as stock position, and you're using the stock flare type of fittings.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 10-06-2005, 09:37 AM   #3
BubbaGreen
I did try a stock hose and the bends dont line up properly, ACDelco part.
The ends of the hose are correct.
