Old 10-06-2005, 09:12 PM   #1
boatpuller
boatpuller's Avatar
anybody done this?
has anyone removed all their a.c stuff underhood,the truck i just picked up only had about half of it,so i've been taking the rest out,in order to get rid of big box in passenger side corner can i just swap a heater blower box in from a non a.c truck?
boatpuller is offline   Reply With Quote
Old 10-06-2005, 10:01 PM   #2
crossy
Oh,you can't buy that new
crossy's Avatar
unfortunately even the hole in the firewall is different. quite a bit different. most of the guys on the boards that are familiar with this swap have gone the other way. I have the same situation here with my hot rod truck but i just painted the box so it looks OK for now. the most important thing to remember about your situation now is that the the AC trucks used an ALL vacuum controls for all the duct work so if the previous owner cut the vacuum line too you wont have anything inside the cab except heat on the floor I think that is what it defaults to. DAVE
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 10-07-2005, 05:27 PM   #3
boatpuller
boatpuller's Avatar
seems to be alot more to it than i thought,i see alot of pics of nice engine bays with an ugly box with two disconnected lines sticking out.i was thinking of fabbing some sort of sheetmetal box about a third that size just for blower and heater core hose's.heres another choice.sorry i don't know how to create a link.but americangraffiti.biz makes fiberglass ac delete boxes.there on the website and ebay,their proud of them though at 129.00 a pop.
Old 10-07-2005, 07:02 PM   #4
Slonaker
Insert Witty Text Here
Slonaker's Avatar
PM Swervin. I think he removed his A/C and modified the box.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 10-11-2005, 10:51 PM   #5
bloertcher
bloertcher's Avatar
You will need all the components from a non A/C truck,including the heater controls.I made a big block off plate from stainless,polished id,then cut the proper holes in it for the non A/C heater box.You can tell what I did if you know what your looking at,but it still looks better than the ugly A/C box hanging there unhooked.
bloertcher is offline   Reply With Quote
Old 10-12-2005, 12:15 AM   #6
corn
I got rid of most of it. I left most of the stock parts intact, just got rid of the under hood parts & the dash vents. I havent run it yet, so I cant tell you what kind of demons Ill run into when I do...
corn is offline   Reply With Quote
Old 10-12-2005, 12:20 AM   #7
bloertcher
bloertcher's Avatar
Hey cornfed,will that thing Pieel out?
Old 10-12-2005, 12:53 AM   #8
corn
I wish I could find out! I need to get off my lazy a$$ & get back to work on it...
Old 10-15-2005, 01:40 AM   #9
bloertcher
bloertcher's Avatar
bigblocks are soooooooooo neat!
Old 10-15-2005, 11:50 AM   #10
boatpuller
boatpuller's Avatar
hey cornfed,what is that cover made out of ? that doesn't look bad.did you trim the box back clear to the core in there?
Old 10-16-2005, 10:58 AM   #11
corn
Re: anybody done this?
If I remember correctly, the core was in the cab & no where near where I cut. I cut it flush with the heater motor level & fiberglassed it.
Old 10-16-2005, 05:01 PM   #12
u2slow
Web Wheeler
u2slow's Avatar
Here's the non-AC cab I used for a template...
... so I could cut out this piece...
Then I cut a piece of sheet metal to cover the old hole, and drilled it for the heater hoses and fasteners.
'66 C10 longstep - Clifford equiped
'84 C20 Suburban 6.2L - awaiting 4x4 conversion
'91 V3500 Crewcab - awaiting diesel swap
u2slow is offline   Reply With Quote
Old 10-17-2005, 04:59 PM   #13
stan79chevy
stan79chevy's Avatar
my 79 was originally an ac cab. i took that whole thing off and put a plate on there with a regular blower. it was after that when i found out about the vaccume controls. i got under the dash and moved the flapper {that directs where the heat is going} from the floor up to the defrost them put a drywall screw in it to hold it. one day i may fix it right but all i really need is defrost anyways.
stan
79 chevy k20 350/350/205/D44/14bFF
4.56 gears rock
LWB pimer black
01 S-10 ZR2 extended cab
4.3/4L60E/233
3.73 gear 31" DICK CEPEK CRUSHERS
stan79chevy is offline   Reply With Quote
Old 10-18-2005, 01:42 AM   #14
longhorn71
longhorn71's Avatar
man i must be the only guy adding a/c I cut the fire wall from an a/c truck and the one from my non-a/c blazer and welded the piece in.I am sure you could do it the other way too.
longhorn71 is offline   Reply With Quote
Old 10-18-2005, 03:20 AM   #15
75silverstep
KEEP ON TRUCKIN.
75silverstep's Avatar
Thought About It But Live In Cali....need That A/c No Matter What Gas Prices Are ...would Love A CleaN Looking Motor Compartment But Cant Do It ...
1975 C-10 STEPSIDE (ALMOST DONE AGAIN)90 percent done wheres that other 10 haha .1994 GMC Z71 .
75silverstep is offline   Reply With Quote
Old 10-20-2005, 01:51 AM   #16
Krosati
you could remove everything and patch in a new smoothe panel, then hang an under dash unit from Vintage air. It really cleans up the interior too.
Krosati is offline   Reply With Quote
Old 10-20-2005, 09:23 PM   #17
boatpuller
boatpuller's Avatar
that would be the ultimate way.would have to save my allowance and reduce the honey do list big time for that to happen!whats a ballpark figure on that setup?
