Old 10-07-2005, 09:35 PM   #1
beenydu
Got Jesus?
beenydu's Avatar
4.3V6 & 700-R4 Changeover
I have a '71 Deluxe with a whopping 250 and 3 Speed. I have access to a 1990 4.3V6 and 700-R4 and am thinking about putting it in. As you can guess the $3.00+ / gallon is making this idea sound sweeter. Has anyone out there done this or know of someone who has? I would really like some input as to what somebody thinks. Is it possible to use the fuel injection or do I have to buy a new edelbrock and demon to put on top? Thank you in advance for all the help. I reallllllly appreciate it!
beenydu is offline   Reply With Quote
Old 10-07-2005, 10:02 PM   #2
LUV2XCLR8
The LuvShack Garage
LUV2XCLR8's Avatar
Never done it, but I contimplated it w/ my old 70 several times, think it would be
Owner/Op: "TN Classic Transport Carriers"
The Toy: "Square Vette" 72 Hybrid Blazer
Toy Barn: "LuvShack" 40 x 60 x 20 Shop
Tow Piggy:"Maddy" 88 Silverado 3500
Hauler: "Feathers" 14 Aluma 8218T
LUV2XCLR8 is offline   Reply With Quote
Old 10-07-2005, 10:22 PM   #3
shifty
Questionable
shifty's Avatar
I hear the setup I'm installing will get over 20mpg highway....but it has to do with the 6spd, something about final drive (overdrive) gear being different than the automatic (4l60e?)
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 10-08-2005, 07:51 AM   #4
beenydu
Got Jesus?
beenydu's Avatar
Well, I figured the 1990 S-10 is getting 18-19 mpg average per tank, so I thought it would get somewhat close to that. I really love the idea of cruising at 60mph and turning 1700rpm. Anybody else out there done it yet? If I do it, I will be sure to take pics and document it very well. That way some more folks can save gas and still enjoy to drive the 67-72s.
Old 10-08-2005, 12:09 PM   #5
tnblazerk5
User #12137
tnblazerk5's Avatar
i may be wrong ,but i would think that it would get worse gas mpg in the 67-72 than in a s10 cause of the weight of the 67-72 ,i got a 91 s10 4.3 5speed and when i put 800 or more lbs in it ,it drinks the gas and when i pull a 5x10 trailer it drinks gas and in both pulling and stuff in the bed the 4.3 proformance sucks
i to would think the 250 and a 700r or a 4le<? would be better or a stock v8 with a 700 or 4le<? with a 308 or higher gear would get better gas than the 4.3
like i said i may be wrong
tnblazerk5 is offline   Reply With Quote
Old 10-09-2005, 07:34 AM   #6
vtblazer
vtblazer's Avatar
Having an overdrive will of course lower your highway RPM's but it all depends on what you have for a final drive ratio in the rear axel.
Interesting swap though.
Does the 4.3 have as much HP as an old style six?
vtblazer is offline   Reply With Quote
Old 10-09-2005, 02:31 PM   #7
vtblazer
vtblazer's Avatar
Another consideration is the "shape" of our trucks vs. an S-10 not to mention the shear vehicle weight difference.
An S-10 has at least the beginnings of aerodynamics. Certainly a smaller frontal area.
Pushing a C/10 down the road at highway speeds will take more ponies/gas.
All I'm saying is I wouldn't expect "as good" where MPG is concerned.
I hear what your saying about the other issue's though.
Old 10-08-2005, 08:24 AM   #8
beenydu
Got Jesus?
beenydu's Avatar
Well, I found some great info that I just read through. Here is the link:
http://www.howell-efi.com/technical_...bi_harness.pdf
I will continue to update as I find out info.
Old 10-08-2005, 11:30 AM   #9
guyryan100
guyryan100's Avatar
why not put in the 700r4 behind your 250? The fuel economy will come mostly from the tranny - not the engine. Would be a much easier & cheaper swap...
guyryan100 is offline   Reply With Quote
Old 10-08-2005, 11:57 AM   #10
beenydu
Got Jesus?
beenydu's Avatar
Well, I have a bad oil ring on #3 and #5. I have oillish gunk building up on the spark plugs and then they foul out. I have put non-foulers on them and I think it helps some. I have not been impressed with the way it runs even after converting it to HEI. I drove it to work the other day and it cost me roughly $18 to drive 40 miles. So, I have been very impressed with the power the 4.3 makes and the dependability of the fuel injection. Winter is coming and cold starts are not to easy. My biggest concern is getting the wiring right and the computer wired up.
Old 10-08-2005, 12:04 PM   #11
djracer
djracer's Avatar
The used 4.3's bring pretty good money I'd sell it and buy a V8! They don't get that good of mileage I would think only 1 or 2 miles better than a V8 and Your truck would have much better resale with a V8!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 10-08-2005, 12:04 PM   #12
djracer
djracer's Avatar
by the way Troy Brown at howell's is a great guy to work with!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 10-09-2005, 12:25 AM   #13
beenydu
Got Jesus?
beenydu's Avatar
Well, this will be a daily driver, so I think it will serve the purpose. I have a salvaged truck that I will be taking it out of, so it shouldn't be very expensive. I hope it turns out well.
  • 1968 Chevrolet C-10 LWB
  • 1969 Chevrolet C-10 LWB 383 Stroker
  • 1971 Chevrolet C-10 Deluxe LWB (Poor L6)
  • 1995 Buick Park Avenue Ultra (Supercharged)
  • 1996 Chevrolet C1500 SWB 4.3 5Spd
Thankful to be blessed by the One who died for me.
Old 10-09-2005, 09:16 AM   #14
beenydu
Got Jesus?
beenydu's Avatar
vtblazer - It looks like it will be similar HP. The V6 may have a few more HP. The big advantage is that I am looking forward to a one-piece rear main seal and center bolt valve covers. That = no oil leaks or very slight ones. It doesn't go out as fast as you put it in. Also I love the fuel injection part. I have found some great information about installing the ECM and converting it over. I think it is something that many more people should consider. Insert key, turn, and drive. No cold start stumble or stubborness. I guess I am most impressed becuase I am a computer geek.
Old 10-09-2005, 12:38 PM   #15
kwmech
How about a tbi 305, still have the v8 for resale and end up with a reasonable amount of hp and torque, mileage will still be in the high teens
Old 10-09-2005, 02:09 PM   #16
68 Stepside
huh?
68 Stepside's Avatar
Someone here on the board has done this swap, they have a silver (I think) stepside. From what I recall they were fairly happy, but I think had mentioned it was a little gutless. I just can't recall the members name off the top of my head, sorry.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
