Old 10-10-2005, 10:06 PM   #1
T_Dilley
Can't tell me nothin'
T_Dilley's Avatar
Question NP205 Shift Pattern
Does anyone know what year/model a NP205 Case with only 4 Lo - Neutral - 4 Hi Came in? And its approximate worth with new seals/gaskets throughout.
T_Dilley is offline   Reply With Quote
Old 10-11-2005, 01:07 AM   #2
Americanrider
All the 205s I have seen are 4 position cases, 2wd Hi, 4wd Hi, Neutral, and 4wd Lo. The post 72 models have the ID tag found above the front driveshaft output, and will list model, manufacture date and gear ratio. It should be about 2" by 1" with a UAW stamp inbedded on it. Here is a pic of a 72 model, Different type of tag but it still has the same info.
Americanrider is offline   Reply With Quote
Old 10-11-2005, 09:24 AM   #3
Rod
Late 69 I figure 205 started showing up. Values..well depends where you are and how many 4x4'ers you have near. I have seen 205 cases for automatics sell for $800...typically around $500 here....but a standard tranny np205 case can seel for less like $350 here. There on ebay enough what an auction and see if its near you to compare.
Other places it the exact opposite and automatic is worth no where near what a standards is.
Rod is offline   Reply With Quote
Old 10-11-2005, 11:00 AM   #4
tnblazerk5
User #12137
tnblazerk5's Avatar
they came in all kinds of stuff like ,chevys ,fords,dodges,internationals, there is several differant configurations of the 205
all np 205s had 4 stock shift positions, 2wd Hi, 4wd Hi, Neutral, and 4wd Lo.
sum had slip yoke rear outputs sum dont the ones without the slipyokes are more popular and worth more
look around on it for the id tag it will tell you what it is ,The ID tag is found above the front driveshaft output(or sumwhere there about) , and will list model, manufacture date and gear ratio
NP205 cases had several different configurations with Ford and Dodge using both married and divorced models and GM using many different input spline types and 2 different bolt patterns.
as far as prices they go from free to $1000 bucks for a fully rebuilt one (fully rebuilt means new gears,sliders ,shifting forks, and barrings and seals and gaskets )
tnblazerk5 is offline   Reply With Quote
Old 10-11-2005, 02:16 PM   #5
T_Dilley
T_Dilley's Avatar
I don't have the case with me. I MIGHT be acquiring it in a trade deal. The guy believes its out of a larger truck that had two rear axles. Possibly a 6x6?!? I am not too great on my knowledge of Four wheel drives. Could this be a possibility?
Old 10-11-2005, 09:01 PM   #6
T_Dilley
T_Dilley's Avatar
ttt
