Old 10-16-2005, 09:28 PM   #1
Jakes-66-K10
Jakes-66-K10's Avatar
Help! Almost done with disc conversion
Well, I pretty much just had to bleed the brakes to finish this project, and was getting excited to start driving the truck again. I started bleeding the other night, and found the two front calipers were leaking badly around the banjo bolts, the rear drum brakes were bleeding OK. So I grabbed a long wrench and tightened up the banjo bolt *real* tight. Still leaking, and to make matters worse I stripped threads on the bolt! Grrr...
So I did some calling around and can't find anyone that has any of these bolts? That suprised me, if Autozone and Checkers carries calipers you would think that they would carry the banjo bolts. I need some help how to get a new one, can't even see any vendors that have them, or the copper washers...
Another odd thing I noticed after taking out this damaged bolt, was that the brake hoses are labeled LH and RH. As it stands right now, I have them hooked up backwards (LH hose on right caliper). I hooked them up mimicking another vehicle, so I didn't think it mattered left or right. Is this part of why it was leaking as well? I thought it was just the copper washers weren't seated all the way, that's why I tightened the bolt so much. I guess I really need to learn how to properly hook everything up. Do you have to line up the hole in the banjo bolt with the hole in the brake hose as well? In all the reading I had done prior to starting this conversion, I don't remember reading anywhere about proper brake hose/caliper assembly.
This is on a 1972 CST/20 2wd, using 72 front end parts. I think the 72 had the brake hose mount towards the front of the crossmember, my stock 70 crossmember has them at the back, behind the A arms - this is why I have my hoses installed at opposite locations.
Jakes-66-K10 is offline   Reply With Quote
Old 10-16-2005, 11:17 PM   #2
walker
walker's Avatar
Re: Help! Almost done with disc conversion
It doesn't matter which hose goes r/l so long as they fit in the little bravkets on the crossmember. Do you have two copper washers per banjo bolt (one on top and one on bottom)? Try the dealers for the banjo bolt, or one of the board vendors. If you have no luck with that, then there is a place here called Arizona Brake and Clutch, if they don't have it, it is not available. Also, wrecking yards are great places froodd stuff like that, might be sure to try NAPA too.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 10-16-2005, 11:40 PM   #3
krue
Designated A-hole!
krue's Avatar
Napa should have them.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 10-16-2005, 11:52 PM   #4
chevymad
Did you use the copper washers that came with the hoses? I've noticed the last couple years now that the washers they send with the hoses don't work. They're not only sized a bit different but they're thinner then the originals. I have better luck reusing the old ones then using the new ones.
70 C10 long fleet, 355/200 4r, 6 lug disc conversion, 3" drop
70 gmc changed to 67/8 chevy, 454 with voodoo cam, th400, all 74 running gear.. in progress
chevymad is offline   Reply With Quote
Old 10-18-2005, 01:36 AM   #5
c10chevy69
c10chevy69's Avatar
I got my banjo bolts from Autozone they had them in a tray behind the counter.
1969 chevy C10 long bed 350 4bbl auto p/disc and 5 lug
c10chevy69 is offline   Reply With Quote
Old 10-17-2005, 01:38 AM   #6
cableguy0
so long as the hoses are fitting right on the caliper side you should be fine. the banjo bolt should be in any auto parts store in the help section. the inside of the end of the brake hose if cut out it doesnt matter where the hole ends up on the banjo bolt. the copper washers should also be in the help section
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
