Ball joint removal
I'm taking the drum spindles off my truck to put on disc spindles, and I'm not sure how to get the ball joints out. I have the tie rod end off, and the cotter pin and castle nut off the upper and lower ball joints.
Is there something else that holds them in? Or do I need to just pound the s out of something? ![]() |
Re: Ball joint removal
the best $25 you can spend is on a service manual
#3 | |
Put the nuts back on before you go beating on the spindle or you may need a new GRILL for your face or worse! That should be all it takes!
Kevin
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
#5 | |
i would tie the spring down just in case. you can either use a pickle fork to seperate or you can just hit the top of the ball joint stud with a bfh. either way you'll most likely trash the old ball joint. top is a little eaier to do but the same principle holds. i had to cut some of the stud off of the driver side lower and pound it with a 5lb sledge to get the ball joint to let go of the spindle.
04 GMC Sierra RCSS 70 CST LWB 04 HD Sportster 1200 Custom |
I always keep a jack under it too but I have pulled lots of them apart the nuts don't need to be tight its just a lot safer! the top one doesn't matter. Usually a good 2lb sledge will get the job done without damage to the ball joints!
Great -- thanks-- Any tips to installing?
67 is sold
I took the lower arm to the auto parts store, had them remove the old and press in the new ball joint, all for $10 or so
![]() Join Date: Sep 2005
+use an hammer to take them out when you need an ball joint press to press them back inalot of autostores loan them out
Anyone ever use this?: http://www.harborfreight.com/cpi/cta...emnumber=38335
Was wondering specifically if the adapters that came with this fit our trucks. |
I bought one and it works great! Its a little tricky to figure out but works great!
Kevin
Stopped by harbor freight on the way home from work... 3pc service kit shown above was on sale for 29.99!!
![]() ![]() Last edited by Jim_PA; 10-21-2005 at 06:01 PM. |
it's not to difficult to figure out. i have the same kit. the 2 thick disc pieces are the pieces that go on the ends of the c clamp. the cylinders go around the ball joint(over the top or under) to either install or remove it. mess around with it a bit and you'll get it. i use a 22mm wrench or a 1/2 drive 22mm soket with a cheater bar to remove and install the ball joints
