Back in the sticks
What I did today...pics
My favorite guy, the UPS man came today. Look what he dropped off:
Back in the sticks
Re: What I did today...pics
Of course I had to put them on
![]() Last edited by red71cheyenne; 10-04-2007 at 08:37 PM. |
Outlandish Trends - FL
looks good. Are you going to shave down those upper tabs? I have clearance problems with those if I try to bolt up some chrome valve covers.
-Bret 67 short-fleet sold! |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Looks like your engine mount frame stands are installed wrong. They should set on top of the frame rail, not underneath it.
Back in the sticks
Dude seriously?
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
#6 | |
![]() Join Date: Jul 2003
1968 Chevy C10 Short Fleetside/Wood floor ECE 4-6 Drop / 406 Small Block 1971 Chevelle 427 Big Block Last edited by Bowtiefreak; 10-27-2005 at 10:38 PM. |
Back in the sticks
67fleet, thanks, no I'm going with the stock looking valve covers, so hopefully it won't interfere.
Tx Firefighter, the factory assembly manual shows them like that. Are you sure mine are wrong? Thanks, Jeff.
#8 | |
![]() Join Date: Feb 2000
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
And Don't Call Me Shirley
![]() Join Date: Oct 2005
Like this....
Rick Tucker 1969 C20/Custom Camper (the Green Machine)Sold 1970 GMC 4000 COE (future Ramp Truck) 1972 K10 Longbed (restoration begins June 2020) |
Saving 1 truck at a time!
That has to be a different style of mount. The standard 2wd small block mounts are impossible to mount under the upper frame rail without some significant modification.
Beat me to it...LOL! It should not be a problem...unless there is an alignment issue.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) Last edited by stllookn; 10-28-2005 at 12:50 PM. |
I am guessing it is a 4X4 and yes it is correct. We should be careful about casting our opinion about without first getting the just of the situation. I just walked out and looked at my two 4X4's and the mounts are under the framerail. So if the truck if 4X4 then its correct if 2wd then it needs to be swapped
Back in the sticks
Ya, this is on the Blazer. Sorry, should have specified that when I was posting pics I guess. Thanks to all that looked and replied. Jeff.
Happy to be here
![]() Join Date: Mar 2000
Those look good. Just curious why you went with 2" rather than 2.5"?
Back in the sticks
N2TRUX, I didn't know there were different sizes of factory manifolds. I just ordered the size that fit. Will it make a big difference? Thanks, Jeff.
#15 |
![]() Join Date: Jul 2004
Lookin good !! Yep, my frame monts are on top of the frame too.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
#16 |
Yes, the mounts should set atop the framerails. That way ,the rails support the mount and engine weight. The way you have them, the two 3/8 bolts are in tension and carrying the whole weight of the engine by hanging under the framerail.
If your bolts failed, the mounts would fall and allow the engine to drop. If they were atop the rails like they should be, you could basically remove the bolts and the engine would still be supported ( though it would move around side to side without the bolts installed)
#17 |
Back in the sticks
Well, I'm glad you noticed them now, instead of me finding out down the road with broken bolts. Thanks, Jeff.
#18 |
red71cheyenne those are right if thats in a four wheel drive and wrong if its a two wheel drive.
69 chevy short wide box project 70 GMC jimmy project |
