Old 10-27-2005, 11:20 PM   #1
FleetsidePaul
R.I.P. E.S.L.L.
FleetsidePaul's Avatar
3/5 springs ?? I dont want it lower in back
My truck has 7 inches of space between the body and the tire in front, and 7 inches between the body and the tire in the rear.
So if I lower it 3 in the front and 5 in the rear won't it be pointing up in front ?
I don't want that.
I'll be putting on lowered shocks with the springs. I have seen 3/5 pic's and they look great, I just am getting stuck on the math.
Here is how it sits now. is it higher in front than usual???
1971 Custom C/20
1970 CST 20
1970 C/30 Flatbed
1983 C/30 Dually
2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350.
R.I.P. El Jay
R.I.P Jessie.
R.I.P Grumpy.
Every day is a gift from God.
FleetsidePaul is offline   Reply With Quote
Old 10-27-2005, 11:26 PM   #2
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: 3/5 springs ?? I dont want it lower in back
looks higher front & rear than usual. The top of the frame rail is higher than the top of your tire!
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 10-27-2005, 11:45 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Do you have an engine and trans in that truck?
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 10-28-2005, 07:26 AM   #4
Dual quad
Smell that burnin' rubber
Dual quad's Avatar
The reason for the difference between front and rear spring drop values is that these trucks originally had a rake (rear higher). So originally, the rear would be roughly 2" higher than the front. With age, the rear springs often settle out more than the front and the truck tends to level out. An ECE 4/6 drop for example will result in an almost level stance with only a slight rake.
Dual quad is offline   Reply With Quote
Old 10-28-2005, 09:14 AM   #5
FleetsidePaul
R.I.P. E.S.L.L.
Yes it does have a 292 and a 3 speed in it. I think it looks higher too. It has some big old shocks on it look like from the 70's could that be the reason. maybe someone was worried about clearance when they put the mags on it.
1971 Custom C/20
1970 CST 20
1970 C/30 Flatbed
1983 C/30 Dually
R.I.P. El Jay
R.I.P Jessie.
R.I.P Grumpy.
Old 10-28-2005, 09:16 AM   #6
Joe67
67 is sold
That will be corrected when you use new rear shock brackets and shocks with the springs
Do the drop
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 10-28-2005, 02:14 PM   #7
67Fleet
67Fleet's Avatar
May have been that the PO put some heavy duty springs in it at some point, or lift springs or something. It definitely doesn't look to have a stock stance. Either way, once you get your drop springs I think it will come down a little more than 3/5 from what it is now. I would also recommend the shock relocators for the rear. I couldn't believe the difference it made to my shock angles out back. They were at about a 45* angle before I put them in.
-Bret
Old 10-28-2005, 05:58 PM   #8
tomatocity
tomatocity's Avatar
The front wheelwell openings are larger than the rear wheelwell openings. I made the same mistake when I was measuring my truck so I could decide how far to drop it. Measure from the ground (level) to the bottom of the body in front of the rear wheelwell and behind the front wheelwell. That should give you your stance. If it is sitting level and you want it lower in the front then you need to lower the front more than the rear.
Got bored, sold everthing. Got bored, looking for a 1960-66 C-10. Want to build my last truck.
tomatocity is offline   Reply With Quote
Old 10-30-2005, 10:47 AM   #9
Tx Firefighter
Early Classic's website has a stance page, which shows pictures of these trucks with varying drops.
Whatever the reason it sets so high now, once you swap all 4 springs out, your truck will set real close to everyone else's truck with the same drop as you did.
Old 11-02-2005, 12:12 AM   #10
FleetsidePaul
R.I.P. E.S.L.L.
I took Tomatocity's advice and measured it from the floor and sure enough it's 16" in the back and 14" in the front. THANKS TOMATO . Also a light bulb went off in my head as I remembered that my truck has brand new lug nuts on really old Slot's (the only new parts on the whole thing) which makes me think that my rims & tires were a recent addition. It probably had some bigger rims & tires on it which explains the gap. Once again THANKS for the help from the board members. I get the jitters before I move on something like this, and it's nice to have some feedback going in. I'll post some pic's when it's done. Thanks to all again.
1971 Custom C/20
1970 CST 20
1970 C/30 Flatbed
1983 C/30 Dually
R.I.P. El Jay
R.I.P Jessie.
R.I.P Grumpy.
Old 11-02-2005, 03:14 AM   #11
HeavyD
HeavyD's Avatar
Are you going to keep the slots? They look really good on there.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 11-02-2005, 01:46 PM   #12
FleetsidePaul
R.I.P. E.S.L.L.
The jury is still out on the slots. I have been polishing decades of crud of them, so depending on how they come out. They look better in pictures.
I really like Chrome Ralleys with the dog dish caps. $$$$$ will decide.
1971 Custom C/20
1970 CST 20
1970 C/30 Flatbed
1983 C/30 Dually
R.I.P. El Jay
R.I.P Jessie.
R.I.P Grumpy.
