Old 10-30-2005, 08:53 PM   #1
1967k30
1967k30's Avatar
283 building questions
How much power can you get out of a 283? What type of carb setup?A 2bbl, 4bbl,3 2bbls .It will be in a 67' 4x4 with 37" or 38" tires and will be backed by an nv4500 5spd.Was thinking it may be pretty efficient and be built to have a good ammount of power.Planning on running propane aw well.Any info would be appreciated.
01 2500 Duramax,6spd,4x4,Not stock. Estimated
550rwhp/1100rwfp on fuel only.
03 3500 Duramax,6spd,4x4,Pac-Brake,not stock Estimated 500rwhp/1000rwfp fuel only
67 K10 in many pieces
Little Brothers truck
67 K20 Cummins 12V/NV4500/205,
D60/Eaton w/ Detroit,37" Xterrains,crossover steering,
Future plans,Twins and lots of fuel.
1967k30 is offline   Reply With Quote
Old 10-30-2005, 09:07 PM   #2
68Stepbed
68Stepbed's Avatar
Re: 283 building questions
I was thinking of building mine with a 305 TPI setup and Vortec heads. I'm not sure about power numbers. Sounds like you'll have a decent running truck there. Do you plan to run a low gear like a 4.11 or 4.56? I know smaller engines like lower gears. Good Luck and keep us updated.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 10-30-2005, 09:25 PM   #3
1967k30
1967k30's Avatar
It's going to be for my little brothers truck. It's going to have 5.14's unless we decide they are too low then we will run 4.56's.We have both sets of gears so it's no big deal.I was hoping to get him some good power an well as be efficient.Plus not very many people have 283's.
Old 10-30-2005, 09:34 PM   #4
I`d go with an RV cam,low-end torque/economical cruising,hei,1.94"heads,4bbl(no more than 600cfm),headers,and flex-fan.If you`re doing a rebuild,you could go to about 9.5:1-10:1,an over-bore(to a 301),balancing,and porting(along with port-matching heads/manifold).
Old 10-30-2005, 09:43 PM   #5
1967k30
1967k30's Avatar
Any idea how much HP?? Could it make 300hp and still be efficient.
Old 10-30-2005, 11:49 PM   #6
bigjimzlll
bigjimzlll's Avatar
A real 300 HP will be real tuff. GM back in the day made 290HP with a 11-1 solid cammed dual 4 barrel 283
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
