Old 11-02-2005, 05:33 AM   #1
zimmm
Low hump to high hump?
Would like any information available regarding converting a low hump cab to a high hump. I am having little luck finding a high hump 4x4 cab and am contemplating purchasing a low hump and using the doghouse from my current cab.
Current cab is beyond reasonable repair - passenger side door A pillar is rotten from bottom almost all the way to the windshield, plus other common rust through areas.
I imagine that someone has done this before and am looking for any issues/problems encountered, as well as other suggestions.
I have thought about installing a bodylift and just cutting a hole for the T-case shifter, but do not want the gaps from the bodylift.
Mike
72 K20 - quote upon getting it home "What did you buy it for if the brakes don't work"
98 Z71, 96 Tacoma + more toys than I can remember
zimmm is offline   Reply With Quote
Old 11-02-2005, 09:03 AM   #2
CUSTOM/10
CUSTOM/10's Avatar
Re: Low hump to high hump?
I've done the conversion and it's realy not that hard. The low hump area of the floor that needs to be cut out is already embossed into the floor. If you take you high hump and place it on the floor of the low hump cab you'll see what I mean. Just mark all the holes, and cut the floor inside of the holes, leaving enough material to weld nuts under the floor, ( drill the hole before welding nuts on ) That's about all it takes.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 11-02-2005, 09:47 AM   #3
Striker169
Car O'Holic
Striker169's Avatar
"( drill the hole before welding nuts on )"
whats funny is im sure someone has done that.
Striker169 is offline   Reply With Quote
