Old 11-03-2005, 02:21 PM   #1
nu2-72
Have you ever seen a spindle spacer?
I have torn down a few Dana 44's and this is the first time I have seen this spacer. It was between the knuckle and the spindle.
Anyone have any knowledge of these?
I can only guess that something was not machined correctly but I really do not know what. Knuckle face too short, spindle too short, or axle too long?
Who has the info?
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 11-03-2005, 02:55 PM   #2
Mudder
Mudder's Avatar
Re: Have you ever seen a spindle spacer?
Looks like a wheel spacer.
Mudder is offline   Reply With Quote
Old 11-03-2005, 07:04 PM   #3
nu2-72
Found the answer. Called Randy's Ring and Pinion. Turns out that after I cleaned it up, it is wedged shaped. .035 on the thin side and .108 on the thick. It is used alot on the West coast it seems. This is for camber alignment. Randy's says that a lot of trucks that see airborn time, knock the fronts out. This is one way to compensate for a bent knuckle "or" some shops use them to make up for a bad ball joint.
I have put everything back into this front end NOS so I see no need to put it back in at this time. If it was used for a bad balljoint I will have it covered. If the knuckle is bent, well, I guess we find that out at alignment time and I already have the shim.
Learn something new every day.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 11-03-2005, 07:08 PM   #4
Yep,not too often they need it.But that`s how the camber is adjusted in Front drive axle.I`ve never needed to use them.
Old 11-03-2005, 10:16 PM   #5
nu2-72
Randy's suggests to rebuild without it and use an eccentric ball joint instead. Had not heard of that one either.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 11-04-2005, 04:18 AM   #6
1976K5CHALET
1976K5CHALET's Avatar
Correct it is a camber adjusting wedge.
The other way to do it is the eccentric sleeve and washer for the top
ball joint which i do not recommend as the damn washer allways breaks
in two after some light duty wheelin. I have allways used the spindle
wedge myself and never had an issue with them. Plus the top balljoint
sleeve is torqued to 70 ft lbs...kinda hard to get that spec when you
are trying to get the camber setting you want.
Doug W.
Doug Wright aka K5NUTT over @coloradok5.com
Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets
Certified K5 Nut
1976K5CHALET is offline   Reply With Quote
Old 11-04-2005, 11:01 AM   #7
kwmech
In my opinion those are much better than using an eccentric ball joint. There should be a number on it somewhere indicating what the degrees are. That looks like the steel version.
Old 11-04-2005, 11:46 AM   #8
nu2-72
Thanks guys. I will keep it just in case the alignment is out when the truck is done. That should be about 5 more years at this rate.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 11-05-2005, 12:43 AM   #9
soleeagle
soleeagle's Avatar
Where would a person get one of these spacers from? I need one for the Burb.
Chuck
'85 Chevy Silverado 4X4
'91 Chevy 4X4 Suburban
http://www.cardomain.com/memberpage/545941
soleeagle is offline   Reply With Quote
Old 11-05-2005, 04:25 AM   #10
1976K5CHALET
I'd start at napa to find them....or a good local parts store...not the chains.
When doing an alignment i allways try to get it as close as possable..so i allways use the spacers. Course now i am converting to cross over steering so i am venturing into unknown territory for a change...lol.
DW
Certified K5 Nut
Old 11-05-2005, 09:46 AM   #11
nu2-72
Since it is actually an alignment wedge, I would try the tire/alignment shops around you that deal with older 4x4's.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 11-05-2005, 10:28 PM   #12
LONGHAIR
If you really "need" one of those to get your alignment right.....something is bent or a ball-joint is shot. This is a "band-aid" ...not a proper repair.
One would hope that if a repair person was in deep enough to put a shim under the spindle that they would find/replace a bad ball-joint. Unfortunately the problem is usually a bent axle housing or a crack where the tube enters the casting of the differential itself.
If the shim is used, it only solves the problem of the wheel alignment, it does nothing about the misalignment of the axle where it enters the spindle, or the axle where it enters the splines of the side gear or the inner axle seal.
I would have the housing checked.........
LONGHAIR is offline   Reply With Quote
