Old 11-03-2005, 04:09 PM   #1
sr67chevyfleet
Question 67 fleetside drive line
this is a question to any one who can answer my drive line bering was messed up so i got a new one i just need me help getting it off and the new one on
sr67chevyfleet is offline   Reply With Quote
Old 11-03-2005, 04:15 PM   #2
70rs/ss
70rs/ss's Avatar
Re: 67 fleetside drive line
I believe it has to be pressed on and off? I'll let someone who knows better to throw in there thoughts.
70rs/ss is offline   Reply With Quote
Old 11-03-2005, 04:34 PM   #3
sr67chevyfleet
Question my driveline please help
I have a 67 fleetside longbox that need some work when i got it now im almost done. My question is regarding my driveline bering. I took out my driveline got a new bering I just cant get the out one off and the new one on. Do I need an gear puller or something I really dont know thanks all for the help
steve
Old 11-03-2005, 04:43 PM   #4
krue
Designated A-hole!
krue's Avatar
I did mine with a hammer and some sockets as drivers if I recall correctly but it's been a while. Might as well replace the u-joints while you're at it.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 11-03-2005, 04:51 PM   #5
krue
Designated A-hole!
krue's Avatar
BTW I merged these two threads for you.
www.daveramsey.com
Old 11-03-2005, 05:17 PM   #6
bejay
once you seperate the driveshaft at the u joint and remove the yoke bolt and yoke the bearing should just slide off you may have to tap on it a little to get it off.
bejay is offline   Reply With Quote
Old 11-03-2005, 05:58 PM   #7
jlmtrout
Before you seperate the drive shaft halves, mark them so that you get them back together the way they came off so you don't have to rebalance the drive shaft. Krue is correct both in using sockets and hammer and replacing the 3 u-joints while you are at it. Good luck and keep on truckin'........Jerry
'68 c-10 long wheelbase fleetside, been in family since new, originally 250 3 speed
Now (389) 350 .060 over 3.75 stroke,Edelbrock Performer RPM 70cc heads and Intake
600 cfm Edelbrock,Small Comp Cams retro-roller cam and roller rockers,9:1 cr, headers, HEI,Old Air a/c, 72 power disc brakes w/stainless lines, 3.42 gear,T-56 6-speed, original paint(what's left of it). Dakota Digital Dash
jlmtrout is offline   Reply With Quote
Old 11-03-2005, 07:16 PM   #8
sr67chevyfleet
Thanks for the helpful hit
