11-03-2005, 05:51 PM | #1 |
Gas tank relocation ideas
I know this has been talked about but was wondering a couple specific things.
I am going to relocate my tank from behind the seat to simply gain more room and get the ugly filler neck moved. My ??? are what will work and be the coolest. I will have a fuel injected motor so I know I will need a return line and a tank with an intank fuel pump would be nice. What fits??? Can I rob a 88-up saddle tank and mount inside the frame or do I have to go the fuel cell route, and if that is the case is it alright to run poly tanks with fuel injection?? Oh ya, this is for my 72 4x4 conversion project. thanks guys
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio ..... 1971 CREWMAX Build.....at body shop for couple more years |
11-03-2005, 06:04 PM | #2 |
Re: Gas tank relocation ideas
I think one of the cheapest/simplest solutions would be to buy a complete blazer tank kit (around $250 for tank/straps/sending unit) and buy an external fuel pump and mount it on the frame. Just my opinion, I think the fuel cells cost too much, but they may be a better fit and tuck under the frame more, but since you have a 4x4 that probably won't matter.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
11-03-2005, 06:22 PM | #3 |
I am looking for something clean, how far do the blazer tanks hang down if mounted fairly tight to the bottom of the bed.
Does anyone have some pisc
11-03-2005, 06:35 PM | #4 |
http://67-72chevytrucks.com/vboard/s...ad.php?t=74876
That's the FAQ someone did on an install. Should give you a good idea on what to do and how it looks.
11-04-2005, 05:27 AM | #5 |
This is a 31 gallon Blazer tank with skid plate. With the bumper I have you can hardly notice the tank at all.
11-04-2005, 09:14 AM | #6 |
Mudder, What year tank is that?? Do you have to have the body lift for it to fit?
Can the sidemarker light filler be done on a fleetside bed w/o a body lift?
11-04-2005, 11:28 AM | #7 |
www.73-87chevytrucks.com
http://www.rockvalleyantiqueautoparts.com/ndex.htm sets up factory tanks for EFI use for Street and Performance. You might can get them to set you one up based on the Blazer relocation setup. If you go this route, I would see if they would set it up with the LS base non return pump setup. I have no idea what this costs though.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
11-04-2005, 11:44 AM | #8 |
67 is sold
Here is some more good info:
http://67-72chevytrucks.com/vboard/s...d.php?t=117123 |
11-04-2005, 03:00 PM | #9 |
That tank came from an 85 Blazer. I bought a newer tank one time but it wouldn't work with my sender. The new tank was for FI. My sender would not go into the FI tank. The body lift was mainly used to get my body lines straight. That is a 77 frame. It could have been set a little lower but it did help with plenty of clearence for the fuel tank fill tube (hose).
10-09-2006, 04:56 PM | #10 |
I am looking into a tank from fuelcellguy or ECE. Do you have to remove the bed for this install? If so, anyone have a how to? Looking to do this in the next month and need to figure out if I can tackle it alone or take it to a shop. Then, I must find a shop.
10-09-2006, 05:12 PM | #11 |
I am getting the Blazer kit from CPP, it's $170 with everything. Not the cleanest, but the easiest and cheapest for sure.
I am using a Buell gas cap as a fuel filler mounted on the side of the bed. |
