72 2wd Blaser spindles will the y work on?
Hey I sure hope I didn't jump the gun again here, but these 2 inch drop spindles I found on Ebay were going cheap 142.00 new so I bought em.
I didn't have time to check the interchage as i was at work when I bid and won so can you guy's give me some insight. they are for a 72 2wd Blaser will they fit on a 71/72 disc brake suspension out of a C10. Thanks ![]()
1970 C10 Stepside (soon to be a 68 w/PS/PB/S&W back-half narrowed F**D 9inch w/Discs) 66 427/435 corvette motor (hopefully 871 Blower) 66 M21 4 speed (swapped in a built TH400) 31/16.5/15 Mickeys (soon to be 29.5X18.5X15 MT) 1972 C10 Stepside Pro-Street 1988 bed 3" Top Chop Custom Red Pearl paint w/overlapping Ghost Flames P/S P/W P/B P/DL P/door open Everything Shaved Frenched antenna 461CI BBC BDS Blower 1100 Dynoed HP TH400 Super Heavy Duty Full Back-Half Narrowed 12 Bolt 4:10 |
Gone Fishing
Re: 72 2wd Blaser spindles will the y work on?
They should work with no problem
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop ![]() 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
TOTY 2006
![]() Join Date: Dec 1999
If they are correct for a 72 2wd blazer, they will work on 71-72 1/2 ton truck/blazer/suburban.
They should also work on 67 - 70 but you will have to change ball joints and outer tierod ends to 71-72. If I am incorrect, someone please add the correct info... |
Thanks Guy's this board is absolutely indespensible.
Now just get lowered springs,finish the prostreet frame(building myself),bodywork,parts,parts,paint and I'll almost be finished!! Thanks again!!!! ![]()
#5 | |
I know what your thinking.......I have ESPN. ![]() Sometimes it's easier to do things the hard way. ![]() Fesler Built 1968 Chevy C10....Must resist the urge to mess with it!! ![]() ![]() |
#6 | |
Old Skool Club
![]() Join Date: Jun 2001
Good price, though.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
