11-04-2005, 12:12 AM | #1 |
4x shift pattern
My 68 doesn't have a pattern on the shifter, could someone help me with the sequence I can't tell where 4 low and 2 high is.
Richard
Not all who wander are lost |
11-04-2005, 12:20 AM | #2 |
Re: 4x shift pattern
My 69 has the Spicer 20 case with the external shifter box. Pattern looks like a capital "J". 2-hi is to the left and up, 4 hi is straight down. 4-low is to the right and up from 4-hi. Of course my hi-low rail is seized in hi range and I haven't had time to fix it yet!
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
11-04-2005, 11:36 AM | #3 |
thanks chris, but my transfer is a 205, straight up and down, where 2 high?
11-04-2005, 11:49 AM | #4 |
Are you sure it is the 205? A 68 normally has the Rockwell T221, unless someone swapped in the 205. The look kind of similar.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
11-04-2005, 01:28 PM | #5 |
Check out GMTrucks.org
If it is a 205, look here:
http://www.gmtrucks.org/wiki/faq/transfer_case Shift pattern is (from front to back): 4wd Low, Neutral, 2wd High, 4wd High |
11-04-2005, 10:03 PM | #6 |
Thanks Scrubby
It is a C20 clone, the gear shifter has a icon of a drive train but no numbers or letters. That site is what I was looking for. Thanks Richard
