11-09-2005, 10:28 AM | #1 |
Aftermarket core support RANT!!!
I have a replacement aftermarket core support for my 71....and have some issues with it and would like to hear from others there experience.
1st, the lower radiator mounts had the weld nuts welded inside the supports, ok, no big issue, ground the down so the rubber inserts would fit. 2nd, went to mount the upper radiator brackets and the drivers side weld nut is not center correctly, ok, enlarged the hole for that radiator bracket into an oblonged pattern and that fit. 3rd, went to mount the battery tray (that fit perfectly on the stock core) and using the pattern on the aftermarket core, it twisted this tray into an unlevel trapazoid. The 3 weld nuts that are closest to the radiator are welded in, in such a manner that they dont run parallel to the core, but follow the bow of the support....I either need to redrill the core -or- redrill the battery tray -or- get a GM replacement core.... I havent even attempted to put the brackets to mount the fenders or fender wells...also, I dont see the weldnuts to mount the charcoal vent canister. If anyone can recommend a good brand -or- actually has used a GM one, Please comment. Thanks!!!
71 Chevy C-10 SWB Fleetside RamJet-350/4L60e & Compushift/3.73Posi See it at www.prismnet.com/~grzanich |
11-09-2005, 10:47 AM | #2 |
67 is sold
Re: Aftermarket core support RANT!!!
Ouch.
I think there is only one company making the reproduction core supports? |
11-09-2005, 11:05 AM | #3 |
I think goodmark makes them, and thier quality is very good. I used a factory quarter panel and it hung perfect.
11-09-2005, 11:24 AM | #4 |
67 is sold
It appears one vendor, Tri-Plus (Taiwan), makes the core supports for the 67/68, 69-72 trucks.
Just spoke with Goodmark, everything they sell is made in Taiwan |
11-09-2005, 11:37 AM | #5 | |
So is the goodmark piece from Tri-Plus? I thought they manufactured their own stuff? Well, my hoods (x's3) and my 70 Camaro quarter fit as well, maybe you got a bad one? It is too late to return it because you have modified it. One other piont to ponder is that a lot of "factory" crap didn't or doesn't fit that well either?! |
11-09-2005, 11:39 AM | #6 | |
67 is sold
Goodmark is only a reseller (with an awesome marketing team)
Joe - Formerly 67c10step ------------------------------- 1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD gr8lakes - My ebay auctions Click here to order forum apparel :: Click here to become a subscribing member Last edited by Joe67; 11-09-2005 at 11:39 AM. |
11-09-2005, 11:25 AM | #7 |
I didn't have any problems with mine, but I bought it two years ago.
11-09-2005, 12:10 PM | #8 |
fugedaboutit
I just did my core support (aftermarket) from Classicheartbeat and the only problem I ran into was the battery tray holes. The 2 that go thru the front lined up good but the 3 down the support were way off. I ended up just using the middle hole because it kept the tray level. I did have a new battery tray too, so that could have been the problem also.
Currently truckless |
11-09-2005, 07:39 PM | #9 |
The goodmark products are no better then the tri-plus as they are the same just reboxed and marked up about 25%. I just got new Goodmark doors and one has 4 push out dents from the stamping used. Hard to imagine that all their BS about QUALITY and it's obvious NO ONE in Goodmark bothers to actually check as this defect is common to every door they produce!! DA!!! I wouldn't buy another Goodmark product again unless it's at or below the tri-plus price!!! Original GM stuff is almost always better then aftermarket--trick is finding it without rust, dents or bondo---for a fair price.
11-09-2005, 08:01 PM | #10 |
Yep, used a triplus core support on my 68, didn't have any radiator problems, but had problems with battery box holes, had to enlarge the holes 1/4 to 3/8where fenders bolt on to get adjustment, had to file the edges down where top of support meets the fenders as it was not square there, also the entire top is a dead giveaway that it is a repro, doesnt have the same bends or shape as original, doesn't hurt any thing and in general it turned out ok, but I will fix the support on my currrent project, rather that buy a repro again.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
11-09-2005, 08:22 PM | #11 |
Project Junkie! Fishing Poor!!
This is the first that I have heard of any problems with the battery tray fitting the core supports. I will be contacting Tri-Plus about the problem once I can take some dementions to give them to relocate the bolt holes and weld nuts. I have used 4 of thier core supports without issues, but it has been over a year since I used one. I will check them with an original battery tray assembly, then one of thier reproductions. Hopefully they will fix the problem, but to be honest with you it could be a crap shoot. I have been on thier cases for 2 years about thier doors having too wide of a gap where the window rolls up and so far they have not fixed that problem. I guess that not enough people have complained about them. Any way it chaps my ass when you can explain a problem, draw up diagrams to fax, and even take multiple pictures to show the problem, and still doesn't get fixed. Don't get me wrong, I do still think that Tri-Plus has the best stuff available, but I sure would improve wherever I knew that there was a problem... WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
11-09-2005, 08:26 PM | #12 |
I got 1 for a guy that had the same problem with the battery box. Must have been a bad run, because I 've sold a few also.
11-09-2005, 08:29 PM | #13 |
Yeah when I bought my core support I could only use 2 of the 3 bolt hole as the other didn't line up at all.
The square holes for the headlight plastic plug+bolts where too big. There was something else too that needed tweaking also before use. Pathetic.
72 Chev C-10 90% restored (former AZ truck) ... 71 Chev K-20 Cheyenne my vacation crusier... 72 Chev C-10 Now retired and striped after many faithful miles... 72 GMC 1500 Retired to the junk yard after bought new in '71... |
11-09-2005, 09:04 PM | #14 |
Designated A-hole!
Note to self....don't buy aftermarket core support.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
11-10-2005, 08:20 AM | #15 | |
67 is sold
11-11-2005, 03:21 AM | #16 |
so why do people want to pay less than half price for original parts in good condition?
11-09-2005, 10:25 PM | #17 |
I bought a Goodmark unit from a local distributor, only to find every blind nut on the wrong side of the unit.
Contacted Goodmark direct, they checked into it and found there was a manufacturing problem. They contacted me back and sent me a new one, and they paid the freight. Totally free of charge. Still have the bad one in the shop. Give them a shot if that unit is a Goodmark product.
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
06-21-2008, 09:29 PM | #18 |
Just digging through some old threads here looking for feedback on aftermarket core supports... It's a rare day to find an original in good shape (no rust/rot) so I'll be buying an aftermarket. Anyone have any recent feedback on Triplus or Goodmark? One of the same still? I can get dealer pricing on Goodmark stuff so it't real tempting to put up with the problems that everyone seems to be having.
Do they ever re-tool to perfect things? I also noticed that Goodmark is selling a "premium quality" front fender. I wasn't aware that they had two different grades.
Baby Blue's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=652776 Project 68's Build Thread: http://67-72chevytrucks.com/vboard/s...17#post8442117 www.stonecolumnclassics.com Email: Josh@stonecolumnclassics.com |
06-23-2008, 04:41 PM | #19 |
Two different grades....you say. Yeah, there's crap and crappier. Seriously, unless you luck out finding decent and workable original sheetmetal, then the alternative is overseas junk. You can cry all you want, so what, as long as they sell 'em they'll continue making 'em the same way. Good luck.
06-23-2008, 05:18 PM | #20 | |
Saving 1 truck at a time!
I wish they would just make a patch panel for the passenger side of the core support and the lower passenger side of the inner fender!!!!!!!!!!!!!!!! They could sell one to every truck owner on the planet...LOL!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) Last edited by stllookn; 06-23-2008 at 05:21 PM. |
06-23-2008, 06:08 PM | #21 |
Amen
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
06-23-2008, 05:15 PM | #22 |
Im glad I found a mint used one up here in SC....I was gonna buy a replacement
"Dixie Destroyer" 71 C10 LWB Fleet Future Blown Prostreet Monster |
06-23-2008, 07:50 PM | #23 |
My buddy got a couple of fenders from Goodmark and his bodyman told him that they needed a ton of work to be straight....he was right. When I looked at them, they had visible seams where there weren't supposed to be any.....I guess he got a very poor stamping [maybe it was a Friday or a Monday].
I will be buying two cowl hoods this year if I am lucky....sure hope they are better than the fenders I saw.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
06-23-2008, 08:12 PM | #24 | |
Was it the correct kit for your truck, it sounds like quite a bit of work.
R.I.P. Scott Kalitta
06-23-2008, 10:46 PM | #25 |
brothers sells a patch for the core support for under the battery tray............
