Old 11-10-2005, 07:20 PM   #1
72swbcamo
Active Member
M Cylinder Prop. Valve. Brake Booster Match
I have seen several posts on the board that states that all three of the brake components: the power booster, master cylinder, and proportioning valve all have to be the same brand. IE: Delco Morine, or Bendix. Is this in fact true and what is the problem with a mismatch. I have a Delco Morine booster and prop vale with with a Bendix master cylinder. The unit is not installed on the vehicle yet so I could switch out the M/C if I have to. Can someone shed some light on this subject for me. Thanks
72swbcamo is offline   Reply With Quote
Old 11-10-2005, 08:17 PM   #2
JimKshortstep4x4
Re: M Cylinder Prop. Valve. Brake Booster Match
There is a problem with the rod length and master cylinder does not fit the booster properly.
There might be exceptions where you can make it work but our practice is to match the MC with the booster.
Jim
Old 11-15-2005, 10:10 PM   #3
72swbcamo
Active Member
Does anyone else have any comments on my mismatched mastercylinder brake booster situation?
Old 11-15-2005, 11:00 PM   #4
FormerMember
I've never had a problem running different rebuilders. I could see different model types I.E corvette with a truck booster, but rebuilders?
I know for a fact I have mixed them up. Bought them at different parts stores that carried different lines. Never had a problem.
I say run what you have, Jim.
FormerMember is offline   Reply With Quote
Old 11-16-2005, 12:59 AM   #5
krue
Designated A-hole!
krue's Avatar
Run what you got, you should be alright.
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 11-16-2005, 03:46 PM   #6
72swbcamo
Active Member
Thanks Grendel, and thanks also for delievering that seat.
Anyone on the board dealing with Grendel, your dealing with a standup guy.
Krue thanks for you input also.
Old 11-16-2005, 07:36 PM   #7
muddpile
muddpile's Avatar
Where are the names stamped on the master cylinder and prop valve? I have looked all over em and can't find one. I have manual brakes and want to add power.
muddpile is offline   Reply With Quote
