11-12-2005, 08:55 PM | #1 |
carrier bearing question
okay i just reinstalled another transmission in my truck finally got it done today was adjusting every thing got going though the gears and i started to smell something burning got undernoeth and the carrier bearing was burning it self up. took it off and took it back to the parts store and got another this one did the same thing expect it had larger coulds of smoke. am i doing something wrong?
11-12-2005, 09:52 PM | #2 |
Re: carrier bearing question
Well it sounds like your doing something wrong, either installing it wrong or buying from the wrong place. Describe what you did when taking the old one off and installing the new one.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
11-12-2005, 11:59 PM | #3 |
i pulled the metal shield off took drive shop to shop had old bearing pressed off . i then tokk the new one slid it on (with metal shield) and bolted the yoke on is it possible i bent the metal shield and its rubbing the rubber parts of the carrier bearing?
11-13-2005, 08:58 AM | #4 |
did you line everthing up like it was when you took it apart
11-13-2005, 09:10 AM | #5 |
yes i marked the drive shaft the way it cam apart and installed new u joints
11-13-2005, 10:38 AM | #6 |
It sounds right to me (the installation), maybe a bad bearing. The rubber should be there just for shock absorption.
11-13-2005, 04:55 PM | #7 |
I ditched those stupid metal shields when I replaced mine...........They looked like they were going to rub so I tossed them.
So far this year I've put in two carrier bearings..............Cummins is not fond of the stock '71 driveshaft/u-joints/carrier bearing...........I am getting a heavier duty setup made at the moment.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
11-13-2005, 08:40 PM | #8 |
When you put in the driveshaft, install the hanger bolts loosely, then tighten rear u bolts on the joint on the rear end. Go back to the hanger bearing and insure that the metal part is centered on the rubber before tightening, also insire the the metal support is at a right angle to the drive shaft, may have to bend the mount on the frame to get it square.
If you tightened the hanger bearing down first and the attached the rear, you will likely pull the shaft into the hanger rubber and burn it up.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
