Old 11-13-2005, 03:05 PM   #1
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Yet another fuel guage problem...
Seems we have been having a few of these lately huh?
Now, I have yet to troubleshoot this, and in all reality, I may not get to it for a while... I have more pressing things on my mind, and more important things to fix on my truck...esp a hand full before the snow flys.
Anyways... on to my goofy POS.
At first, back in the day of the Pontiac 350, and then into the caddy 425 days (or day to be a bit more acurate) the fuel guage worked fine.
The Cad 500 got tossed in there, but nothing was noticed/not noticed right away due to a couple problems.
I did end up removing the tank, thinking it was filled with peeling POR15, which I was wrong, the fuel pump (electric) crapped out on me, however, there was nothing chainged, the same tank and same sender was reinstalled...and the tank IS grounded fine. (I am very anal about my grounds)
Also, at the same time, I removed my inst panel to replace my aftermarket bum mechanical temp guage (ever seen a mechanical one goe bad???) and installed an electric aftermarket one. The printed circuit board was looked at, like I always do when the inst panel is in my lap. I've seen too many with burnt lines on them to just ignore them.
Full is at 1/2 tank, and the lowest I have run it was to 1/8 tank, but I filled up and put in 21 gallons (!!!!!) at that point, so I was 100 feet from running dry most likely. (stock in cab tank)
So, I know there are eleventy billion variables here... however, has anyone seen this before? Just looking for some quick checks before setting aside a bunch of time to look at it.
Oh yeah, and since my speedo cable broke, and I have YET to locate a replacement, I can't just go by the miles driven. I don't know if I should trust this guage to get worse, or if it is going to stay like this. I do know that the top end (1/2 on the guage) has continued to be full.... and I try not to run it below 1/2 tank (1/4 on the guage)... makes it feel cheaper when refueling.
Old 11-13-2005, 06:16 PM   #2
byrd
Union Electrician
byrd's Avatar
Re: Yet another fuel guage problem...
I would change the resistor, being that the gauge is good but not accurate. I know I don't have to explain this to you, but in my opinion it is the resistor for that main reason. not enough resistance to give accurate readings from the sender or too much resistance to give accurate reading. plus it is the cheapest part to replace and te easiest to boot. Randy
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 11-13-2005, 08:13 PM   #3
Longhorn Man
That's kinda what I was thinking... just wondering if anyone else has seen it before.
Old 11-13-2005, 08:19 PM   #4
jhow66
jhow66's Avatar
Look here"
www.fix-a-gauge.com
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 11-13-2005, 11:12 PM   #5
byrd
Union Electrician
byrd's Avatar
Originally Posted by jhow66
Iagree best place and great price imo
Zip:40272
Old 11-13-2005, 08:43 PM   #6
68 Stepside
huh?
68 Stepside's Avatar
I've seen it before, but the problem was never diagnosed in that case...so I guess I can't help. My buddy had a late 80's S15 that did the exact same thing.
Someday when I'm lonely,
Wishing you weren't so far away,
Then I will remember
Things we said today.
RIP El Jay
68 Stepside is offline   Reply With Quote
Old 11-13-2005, 10:37 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
My Haynes manual shows a resister in the fuel sender or at least there is a symbol for one. I don't know the value for it offhand but the sender wire runs to the fuse block as you know so check the connection across the fuse and see if there is any corrosion or bad contact there. The sender may be bad also. I agree that it is probably the guage resister. At least we know what it's value should be. I see the thread you started made it to the FAQS.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-13-2005, 11:25 PM   #8
Longhorn Man
the fix a guage thing... bummer you don't know what you're getting. Or did I overlook something.
Plus, they ask if you are stuck on 1/4 tank... mine works, just on a much smaller scale.
I can look at the fuse and connections....resistance causing corrosion makes sence.
Old 11-13-2005, 11:58 PM   #9
70c10
67-72 Addict!
70c10's Avatar
Andy, when my dads was reading low it was because of a pinhole in the float. I refused to believe it. I popped it out and submerged it under water only to see the air bubbles prove it.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-14-2005, 12:20 AM   #10
Longhorn Man
You know, i thought about that...but it has been consistant for 3 months now.
Old 11-14-2005, 08:22 AM   #11
byrd
Union Electrician
byrd's Avatar
Andy,
The fix a gauge, is a resistor with two short leads and fork lugs on the ends dipped in plastic(to hide the color bands to decifer the amount of resistance)
Installs in about 1 minute flat and if you get one from them and it doesn't fix your problem I will buy it from you, so that you are out nothing and I can always use an extra one around. Randy
Zip:40272
Old 11-14-2005, 04:36 PM   #12
Longhorn Man
well honestly, i couldn't even ask that of you...buying a $75 item becouse it doesn't fix my junk...and besides, I don't have 75 bucks.
I WILL however, book mark that and keep it for reference and look back if need be.
Old 11-14-2005, 05:48 PM   #13
jhow66
jhow66's Avatar
Costs $7.95
Old 11-14-2005, 05:54 PM   #14
Longhorn Man
wow... i feel like an @ss now. lol!
I coulda SWORN it said 74.99....
oh well.
I guess it IS something to consider then huh?
Old 11-14-2005, 06:04 PM   #15
70rs/ss
70rs/ss's Avatar
oh well.
Man a whole guage is $29.95! I am too am trying the resistor as my guage is stuck at a quarter of a tank as well, wanna buy mine if it doesn't work!?
70rs/ss is offline   Reply With Quote
Old 11-14-2005, 08:42 PM   #16
byrd
Union Electrician
byrd's Avatar
oh well.
I keep saying it is the CHEAPEST thing to replace and also happens to be the easiest as well
Zip:40272
Old 11-14-2005, 08:41 PM   #17
byrd
Union Electrician
byrd's Avatar
where are you getting fueal gauges for 29.99? everywhere I have seen them they are asking at least $69.99 to 79.99. and yes 70rs/ss I will buy it if it doesn't fix the gauge, Randy
Zip:40272
Old 11-14-2005, 11:02 PM   #18
70rs/ss
70rs/ss's Avatar
I believe it was LMC, I know nobody likes LMC, but that guage price is just right.
Old 11-15-2005, 12:03 AM   #19
byrd
Union Electrician
byrd's Avatar
Just looked it up and you were close $38.98, still a good deal, but I bet their s/h would be at least, $10.00 or more. Thanks for the tip .
Zip:40272
Old 11-15-2005, 12:13 PM   #20
70rs/ss
70rs/ss's Avatar
I must have an older catalog, and yeah I think they charge a minimum for shipping. I am doing the resistor, because my guage is set at 1/4 tank which is tell tale for the resistor, but I mentioned new just as a frame of reference, especially if it might be more than the resistor.
Old 11-22-2005, 05:14 PM   #21
70rs/ss
70rs/ss's Avatar
I just went back and looked in the fall 2005 catalog and they are 29.99, (they list for $34.99, but they sell them for $29.99) anyways I just ordered the fixaguage part, hopefully mine will join the world of the working guages soon!!
Old 03-04-2006, 10:19 PM   #22
Longhorn Man
Update....
it was the resistor.
Thanks.
