11-15-2005, 05:05 PM | #1 |
engine question
In my truck is a built 350 I have the sheet from builders wondering if you guys can guess at hp and lbs?
1970 4 bolt main bored .030 cast flat top pistons 350 heads w 1.94 int and 1.55 exh 3 angle valve job ssi valve springs crane energizer 1.5 full roller rocker arms with poly locks hardedned tips and push rods. comp cam extreme energy 256 hydraulic camshaft and lifters duration @.050: 212int 218 exh, lift .447int .454exh .010-.010 cast crankshaft accel hei with super coil msd module edelbrock performer air gap intake idle-5500 holly 750 headman headers
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
11-15-2005, 05:22 PM | #2 |
Re: engine question
What's the compression ratio?
11-15-2005, 05:26 PM | #3 |
Re: engine question
could not tell you, runs good on pump gas so I would say around 9.00-1 to 9.5-1
