11-16-2005, 02:26 AM | #1 |
SlickSierra
Could it be done?
I was wondering if I could run a rear suspension set-up like N2TRUX with a 465 horse motor. I know it would cause bad axel wrap but I was thinking that I could run a set of traction bars under the leafs to help prevent this. Any info would be greatly appreciated. Thanks in advance
'77 GMC Sierra 2wd SWB 355SB, TH350 |
11-16-2005, 07:10 AM | #2 |
Re: Could it be done?
If you really are making that kind of power, and intend to use it, you would be better-off with some ladder bars mounted inside the frame. With that many leaves removed you will have severe wrap problems and wheel hop. Slapper type bars are not the greatest thing anyway, plus they will hang really low on that type of a set-up. Ladder bars and housing floaters are the economical way to get what you need.
11-16-2005, 02:43 PM | #3 |
SlickSierra
Thanks for the info I will look into it.
11-16-2005, 10:18 PM | #4 |
Outlandish Trends - FL
If you're looking to put some serious HP to the ground, I'd look into a custom 4-link setup with coilovers.
-Bret 67 short-fleet sold! |
11-17-2005, 12:20 AM | #5 | |
SlickSierra
Does anyone know where I could find either a bolt on or weld on 4-link for fairly cheap?
'77 GMC Sierra 2wd SWB 355SB, TH350 Last edited by SlickSierra77; 11-17-2005 at 12:21 AM. |
11-17-2005, 12:23 AM | #6 |
Project92 SWB stepside
Putting a set off Ladder bars in the frame is pretty easy to do. You could go with a Shockwave bag.
92 C1500 stepside 496 Stroker Competiton Engineering Ladder bars/QA1 coilovers. Dana 60 rear with 4.10 gear and posi. Bonspeed Palisade 20x12 in rear w/335/30/20 and 20x8.5 front w/245/40/20. 5/8 drop with Belltech springs/DJM spindles/drop shocks. WWS Progress thread http://67-72chevytrucks.com/vboard/s...d.php?t=140448 |
