Before and After
I would like to put 2001 center caps on my ralley wheels. The problem is that the center caps thread on to the lug nuts of the wheels. And of course, the nuts don't interchange but they are close.
If I get new studs and nuts, (I believe that they are either a bit larger or have a different thread pattern). Will I be able to just press (hammer) the old ones out and the new ones in ? Without taking them out, I'm not sure of the length for the disks up front and the drums out back. Are they the same length? ![]()
Not Grandpa's C-20 anymore... 383 Stroker 425HP, 485Ft/Lbs Lowered 3.5" Front / 5" Rear 66,000 miles. Alberta, CANADA |
I am just now installing a set of new HD alloys on my 72 C20. I bought new 9/16 lug nuts that were double threaded just like th e new metric lugs at WWW.jaeeagle.com
The only problem is the wheel center cap on the rear axle will not cover the rear hub without about 7/8" gap between wheel and the cap. I have used the original lugs on the rear first and the double nutted with the new style lugnuts. I'm thinking of trying a set of 8 lug 1/4 spacers behind the wheel first and do some grinding on the back of the cap to narrow the gap. HF
'66 CST BBW swb fleet 327 fac ac '67 CST 4x4 swb 327 stepside project '72 Cheyenne K20 50k original '72 Cheyenne Super K20 project '73 Sierra swb 4x4 frame off in paint stage '74 Cheyenne Super swb w/16k actual '71 & 72 Cheyenne K10 4x4 swb's '70 426 HEMICUDA conv SHAKER 4 sp Dana 60 '60 Impala conv 327 PG fac ac loaded 3rd owner '72 GMC K2500 4x4 '59 Apache CST BBW fleetside swb 283 '73 ElCamino SS LS1 T56 true SS bucket tach '76 ElCamino SS 52k survivor '87 Grand National 41k True 2nd to last built in 1987. '86 K30 454 SRW fleetside CA since new '88 Trans Am GTA 39k bought new 2018 DEMON plum crazy @ 840HP! "Need for speed" |
Thats the Hillbilly way
WB 70 ;
There is a Company in Mira Loma Cal. that has the lug nuts to adapt the late model wheels and center cap to our trucks . PM me if you need his # . Bill ![]()
BILL Torrance Calif 90504 Member DUF Club Member Old Farts Club 72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion. " If I knew I was going to live this long I would have taken better care of myself " Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER.... Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen , |
Before and After
I like your idea of spacers and a grinder. I also have access to the HD rims, but I'm not sure if they will look OK. My truck is 20% steel and 80% rust. Can you post a photo of the truck with those rims on?
I am getting my new BFG RWL tires mounted on the new HD alloys
on Friday so I will take pictures this weekend and post them. I did dry fit the wheels without tires and the front fit perfect and the rear only had the cap problem. THe lug nuts look just like the oem metric ones and are even gold cad plated and worked great. A lot less hassle than buying new studs and replacing them. We'll post this weekend. HF |
