Old 11-21-2005, 10:35 PM   #1
BowTieMan
BowTieMan's Avatar
Axle Shafts
Ok so I was at a junk yard the other day and they had a pile of axle shafts from all these different Chevys. Would it be a good or bad idea if I just got those and put them in my rear end so I could get 5-lug? Right now I have a 70 6 lug 12 bolt. So what will I have to look for the figure out which ones will fit right?
I plan to jsut do the axles shafts and later get a 3:73 gear and posi put into my rear end have now.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo
BowTieMan is offline   Reply With Quote
Old 11-21-2005, 11:25 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Axle Shafts
if you have a late 70, you can do this.
70 was a cross over year on the 12 bolt rear. The early ones were narrower than the later ones. If you have the later one, you can use any axle out of a 5 lug 12 bolt truck rear.
Old 11-21-2005, 11:47 PM   #3
BowTieMan
BowTieMan's Avatar
Re: Axle Shafts
So where can I measure to see which I have? My truck was first registered on 11/69 if that says anything.
Old 11-22-2005, 07:17 AM   #4
JimKshortstep4x4
Re: Axle Shafts
If you measure between the backing plates on the rear end, the narrow one will be 56" and the wider one will be 57 1/2". If your rear end measures 57 1/2" between the backing plates then the 71 (5) lug axles will work.
Although you can stick the 71 axle in a narrow 70 rear end the 3/4" length difference lets the axle bearing ride on the edge of the ground surface. (The axle shaft acts as the inner race for the axle bearing).
If you have the narrow rear end, redrilling your existing axles forthe 5 lug pattern is still an option.
Jim
Old 11-22-2005, 11:48 AM   #5
crazy longhorn
Fabricate till you "puke"
Re: Axle Shafts
Another route on the narrow axles, is to go aftermarket. I have Moser axles in my 69, & atho a little more expensive, they are new/straight/non worn pcs The set was around $260 shipped to my door.....if you look around, you may find some others a tad cheaper(try Summit, Jegs, or some of the online differential services). best of luck, L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 11-22-2005, 05:37 PM   #6
BowTieMan
BowTieMan's Avatar
Re: Axle Shafts
About how much would redrilling cost at a machine shop?
Old 11-22-2005, 07:17 PM   #7
crazy longhorn
Re: Axle Shafts
Im not sure, but Ill bet you are looking at $160-170 in machine work(unless you have a buddy to help you)......maybe someone will chime in? L
Old 11-22-2005, 08:21 PM   #8
raggedjim
raggedjim's Avatar
Re: Axle Shafts
In addition to the redrill you would have to turn down the center protrusion that fits in the center hole of the rear drum a bit. I did this years ago, but can't remember much about it... I used new 5 bolt drums and they wouldn't fit because of the center hole.
Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 11-22-2005, 11:25 PM   #9
BowTieMan
BowTieMan's Avatar
Re: Axle Shafts
Ok so I measured it and I got the wider axle, so what year trucks can I get the shafts from?
Old 11-23-2005, 09:35 AM   #10
raggedjim
raggedjim's Avatar
Re: Axle Shafts
71-72 fer sure, not so sure about the 73-84... although I think I saw a thread once saying they would fit also. I'll see if I can dig it up.
Good luck, Rg
Roger
'70 GMC Jimmy 2wd
Old 11-23-2005, 03:00 PM   #11
crazy longhorn
Re: Axle Shafts
71-82? (82 I think was the end of the 12 bolts), should all swap. to be sure, you can measure from the flange to the "button" end . I had the measurements when I ordered my axles.....but its been a while, & the old memory "aint as good as it once was" L
Old 11-23-2005, 03:52 PM   #12
Longhorn Man
Re: Axle Shafts
Am I remembering wrong...or the axles out of the 10 bolt will fit in there too. (the 7? to 87)
However, somewhere in there they went to metric studs which would be a hidden cost...
Old 11-23-2005, 04:18 PM   #13
crazy longhorn
Re: Axle Shafts
Ill bet thats right, the 10 bolt truck rears were also 30 spline on the axles! Metric studs......yup, but I dont remember just where(early 80's?)
Old 11-23-2005, 08:32 PM   #14
Longhorn Man
Re: Axle Shafts
I want to say 82 or so.
Old 11-23-2005, 09:10 PM   #15
crazy longhorn
Re: Axle Shafts
That sounds right to me Andy I remember helping a bud swap a rear in a Malibu wagon.....the wagon was a 79, & it got an 82 diff. the end of the story had the guy giving me he!! for the "metric lug nuts" off my shelf. I told him......he!! , I play with OLD CHIT out here......if there is anything metric, you bruoght it here bud crazyL
Old 11-23-2005, 05:02 PM   #16
chevy283
chevy283's Avatar
Re: Axle Shafts
it cost me $120.00 to get the axles redrilled. For the drums i used 91 sub backing plates and drums.
65 c10 tore apart
70 c10 305/350th
chevy283 is offline   Reply With Quote
Old 11-23-2005, 10:27 PM   #17
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Axle Shafts
My 83 still had normal 1/2 inch studs.
Me no saavy metric....
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 11-28-2005, 12:02 AM   #18
67-72chevyman
Re: Axle Shafts
What is the length of the axles of the narrow rearend?
67-72chevyman is offline   Reply With Quote
