Old 11-25-2005, 03:12 AM   #1
krue
Designated A-hole!
krue's Avatar
What's it called?
I need to stop a leak between the tranny and xfer case of my 72 Blazer. It's a th350 tranny (I think) with a 205 xfer case (again I think). What do I need to tell the parts guy I need?
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 11-25-2005, 06:00 AM   #2
JIMs70GMC
user # 2756
JIMs70GMC's Avatar
Re: What's it called?
output seal of the tranny and an input seal for the transfercase.
1970 K25, 8' stepside bed 350/465/205 44 up front, 60 in the rear 4.10s rolling on 33" Dunlop MTs
1986 K5, 350/465/208 Dana 60/14 bolt from a cucv 36" Super Swampers TSL/SX
1983 K20 w/ CUCV axles, 350/700R4/208 sitting on 37" Goodyears
1986 M1031 6.2 diesel, TH400/NP205 locker in the rear and a LS in the front, all stock for now.....
1986 K30, 350/400/205 dana 60 and 14 bolt. I kept the drivetrain. Body/bad and chassis are gone.
1981 K30, 350/465/205 dana 60 and dually 14 bolt. Has a G80, and a flat bed. Going to replace the flat bed.
1985 K20, 350/400/208 10 bolt and SF 14 bolt. I wonder where I can find some 1 tons. Hmmmmm
JIMs70GMC is offline   Reply With Quote
Old 11-25-2005, 08:51 PM   #3
orange72blazer
orange72blazer's Avatar
Is it leaking tranny fluid into the transfer case?
1972 Chevy Blazer
1997 GMC Sierra
2009 Chevy Tahoe
orange72blazer is offline   Reply With Quote
Old 11-26-2005, 04:32 AM   #4
1976K5CHALET
1976K5CHALET's Avatar
Since you will have the tcase on the ground...the adapter has two seals inside it to seal the trans from the xfer. Being a gen1 K5...assuming things haven't been swapped around the coupler will have a large bearing on it...the seals point inwards. Make sure the coupler splines are not worn out. You'll need a rubber square cut oring that seals the back of the th350 to the adapter...and if you do the coupler seals which i highly recommend...you'll also need the paper gasket that mounts the xfer to the adapter...so that would be a total of 4 seals to do it right.
DW
Doug Wright aka K5NUTT over @coloradok5.com
Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets
Certified K5 Nut
1976K5CHALET is offline   Reply With Quote
Old 11-26-2005, 11:59 PM   #5
krue
Designated A-hole!
krue's Avatar
Thanks guys.
www.daveramsey.com
