11-26-2005, 07:40 PM | #1 |
crossmember drop...help
Hey guys,
I finally got all the wireing done for my new welder so I started to tackle my crossmember drop this afternoon and everything was going great, my sawzall cut through the crossmember like butter. Only problem I am running into is cutting the inside line where the "L" shape A-arm mounts sit. I tried the sawzall at an angle; no luck, tried the cut off wheel; no luck. My next thought it to grab the torch and then grind it smooth. I really dont want to use the torch cause I only have my small one set up and I need to get new bottles for my large torch. So I was just curious what you guys did when you got to where I am stuck at. I know I cant be the only one to have problems. Thanks Keith |
11-26-2005, 10:39 PM | #2 |
Re: crossmember drop...help
I just used a longer sawzall blade and had no prob
66 C10 (under construction) 1.5" crossmember drop 2" Z'ed frame 8" rear notch Watts-link Bagged DJM 3" spindles |
11-27-2005, 01:01 PM | #3 |
Thanks DM,
I will give that a try this morning and see how that works out. I started to think if that doesnt work out just taking the frame mounts off the crossmember and cutting them that way and then welding the mounts back on. Keith |
