Old 11-27-2005, 11:09 PM   #1
Green Machine
Green Machine's Avatar
Sport Mirror Problem - Help !
Bought a pair of repro sport mirrors for our 70 C10. Did a trial fit/measure up before drilling any holes, driver side will be fine. Passenger side measures about 8 inches back from front of door to front hole of mirror, approx factory location, mocked up mirror as high as possible as backing plate will allow before hitting bodyline ridge above it, best location is about 1/2 inch farther back than factory location, as none of the top of the mirror is blocked by the vent window channel.
Even mounted as high as possible a little of the bottom inside corner is still blocked by the door, and a bigger problem is the the mirror cannot be tilted inward far enough to even catch a slight view of the bedside, the mirror nearly hits the base and runs out of swivel at that point. I like to see just the slightest hint of bedside in the mirror for an idea of where things are in relation to the truck.
I bought these mirrors from Chevy Duty and they seem to be good quality. Does anyone have any adjustment suggestions or should I try a different brand ? Or is that about as good a view as you (or anyone else) can get with the sport mirrors ???
Any good looking mirror options ??? Thanks in advance.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 11-28-2005, 12:32 AM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: Sport Mirror Problem
We put my mirrors in the factory location, and actually you can't see out of the passenger mirror. They are hid a little bit behind the vent window and no... you really can't use it, but it's factory. I don't even use it ... it's all for looks. Hope this helps. sorry no adjustments stories here. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 11-28-2005, 02:43 AM   #3
Richard
The RH mirror is located about 3/4" farther back than the LH from the factory. I mounted my passenger mirror an inch futher back and will probably go another 1/2" when I change out the crappy repop door skin for my NOS one.
Richard
Old 11-28-2005, 03:06 AM   #4
truckdude239
truckdude239's Avatar
okay i know this is an stupid and not meaning to highjack this thread but i hear everyone talking about nos parts what does nos stand for?
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 11-28-2005, 03:14 AM   #5
Richard
New/Old/Stock. Generally reffered to as an OEM (original equipment manufacturer) new uninstalled part that has been on the shelf for many years. The parts are not always perfect as they have been around for a few years. But the parts can fit better and most of the time do, as they are the parts a dealer would have used for a repair.
Richard
Old 11-28-2005, 10:56 AM   #6
Green Machine
This truck is going to be daily driven when it's done by my 16 yr old son. Is even the drivers side sport mirror large enough to be any good ??? Not going to be pulling a trailer, how about using the earlier style arms like from a 68 with a 5x7 mirror head ? Would that be much better ??
Old 11-28-2005, 12:50 PM   #7
grebus1
grebus1's Avatar
I put the sport mirrors on my Burb and agree that you really can't see much out of the passenger side mirror. I have also thought about changing to the '67-68 style (I've heard that they do a pretty good job), but isn't the mounting location in a different spot? I'd rather not drill more holes (not to mention uncovering the ones already there).
'72 Chevy Suburban Custom Deluxe 10, 402/TH400
grebus1 is offline   Reply With Quote
Old 11-28-2005, 12:57 PM   #8
409biscayne
409biscayne's Avatar
67-68 mirrors mount way forward . The furthest forward of the three holes is about 2 inchs back from the door edge , under the vent window . At least thats where they are on my 68 , they work well though . Hope that helps . Later.
Can-Am Motorsports
37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser .
64 Biscayne 409 2x4 4 speed 4.11 posi
65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon)
68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD)
409biscayne is offline   Reply With Quote
Old 11-28-2005, 01:00 PM   #9
truckdude239
i'de like to know more about these i got little plastic mirriors the op put on the and if you hit an bumb the driver side moves lol
David fuller
2000 Tahoe 5.3l 378
Old 11-28-2005, 01:41 PM   #10
70c10
67-72 Addict!
70c10's Avatar
The mirror arms are too short in my opinion. If you put those little 1.5" round spot mirrors on the corner of the mirror it helps alot.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-28-2005, 01:50 PM   #11
loblazer
loblazer's Avatar
I got mirrors from the wrecker off 95 Ford ranger (same ones on the Aerostar van). They have a good size mirror and have a lot of adjustment and look good. They were factory black so I painted them to match my paint job.
If you get a pair, watch when you take them off. The two screws go into a backing plate. Don't drop it in the door, you will want it for mounting on your doors.
Send me your email if you want pics of mine.
Doug
loblazer is offline   Reply With Quote
Old 11-28-2005, 07:19 PM   #12
MrC1
Dork For Days
MrC1's Avatar
I recently swapped over to the small mirrors as well. I also had/have the same problem. The psgr mirror is too small to use from that distance. I would like to find something about 50% larger to put on that side, but somehow retain the factory look of the mini-mirrors.
Answer: No, you're no alone. It's bad design.
1972 C20, 402/700R4 - My first classic truck, bought in September 2005. 85% transformed from "Farm" to "Cool" status!
1970 Dodge Challenger 440, 4sp (my other toy) 12.67 @ 117 MPH, with a pathetic 2.022 60'
2007 Dodge Charger SRT-8
2008 Cadillac CTS
All-American garage, baby!
MrC1 is offline   Reply With Quote
Old 12-19-2006, 12:13 AM   #13
DANL
Do you think part of the problem may be the following is not printed on the sport mirror:
Warning: Objects in mirror are closer than they appear.
DANL is offline   Reply With Quote
Old 04-24-2016, 12:07 AM   #14
'68 Newtricks
'68 Newtricks's Avatar
Anyone want to address this? I bought a convex passenger mirror just for this reason. I'm hoping I can see out of it. I replaced my '85 blazer mirrors with '06 chevy mirrors, not gunna do that on the '68.
'68 C10 SWB
'85 K30 Blazer
'68 Newtricks is offline   Reply With Quote
Old 02-19-2012, 10:56 PM   #15
72 K20
72 K20's Avatar
" We put my mirrors in the factory location, and actually you can't see out of the passenger mirror. They are hid a little bit behind the vent window and no... you really can't use it, but it's factory. I don't even use it ... it's all for looks. Hope this helps. sorry no adjustments stories here. Trevor "__________________
The Mirrors from brothers won't adjust in either.
Where would I find a replacement glass for an OEM sport mirror ?
My passenger side mirror is cracked,, probably from the PO trying to adjust it !
I am going to try something on the passengers side swivel ball to try to get enough swivel so I can use it.
Any other ideas , answers, or solutions to the " can't turn the mirror in enough " problem would be greatly appreciated !!
Thank You ! Tom
72 K20 is offline   Reply With Quote
Old 03-26-2012, 03:26 PM   #16
29od1
Thank You ! Tom
What I had to do, to get the passenger side to swivel enough to be able to see out of it, was to grind the edge of the part that the ball sits inside (the main part of the bracket, not the part that the mirror attaches to).
After a couple of trial fits and grinding, it's as usable as it's going to get for the sport mirrors. I also mounted it in the factory location about 8-1/4" rearward from the edge of the door on the pass side.
This is a good thread with mounting location info:
http://67-72chevytrucks.com/vboard/s...bruce88&page=4
29od1 is offline   Reply With Quote
Old 03-26-2012, 10:04 PM   #17
72 K20
72 K20's Avatar
Thanks for the tip !! I would like to see a picture if I could . What you described is what I thought I'd have to do .. What did you use for a grinder ?
Thank You !! Tom
Old 03-27-2012, 09:09 AM   #18
29od1
Thank You !! Tom
I'll try to get some pics tonight and post them. I actually used a metal grinding bit on a small 90 degree die grinder to do it. You have to tape the surrounding area up with 3-4 layers of painters tape just incase the bit slips, you don't want to mark up the mirror bracket. Just take your time and be patient when doing it.
Here's a pic of the type of grinding bit I used. I suppose a Dremel and bit would work also.
Old 03-27-2012, 12:52 AM   #19
67ChevyRedneck
67ChevyRedneck's Avatar
WOW this was originally an old thread!
I too had originally bought "sport mirrors" for my truck but after mocking them up I too realized they sucked. I bought a set of 67-70 style mirrors instead. I think they look cooler and are actually functional!
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-28-2012, 06:18 PM   #20
72 K20
72 K20's Avatar
Thank you for the info !! Looking forward to the pic of the back side of the mirror !!
Thank You !! Tom
Old 03-29-2012, 07:21 AM   #21
29od1
Here's a pic of the passenger side mirror (albeit a very poor one) that shows the little lip area that you need to radius. You only want to grind on the stainless lip part that the mirror attaches to, not the ball itself. I think the ball is chrome plated and it would start to rust if the plating is ground off.
It took a couple of trial fits and grinding, the mirror now can turn toward the cab enough so that I can see out of it directly behind the truck. I'm not sure if the original mirrors were this way, the ones I have are repops. Hope it helps.
Old 08-15-2014, 11:17 AM   #22
Steve Cole
Looking at that pic, it looks like the mirror is contacting the arm before the ball housing? even comes into play. This is my problem anyway, the mirror contacts the arm before anything else hits. I don't see how what you did fixed the problem. Can you show pics of the finished product?
Thanks.
Steve Cole is offline   Reply With Quote
Old 03-30-2012, 05:36 AM   #23
72 K20
72 K20's Avatar
Thank you for the picture . That took a little finesse to trim that edge without knicking the swivel ball !!! Nice work !!
It's a shame that a person has to remanufacture reproduction parts to make them perform the way they are advertised to !!
I returned the repops I had bought,,, the 4 rivets on the back were starting to rust within a month on both mirrors.
Thank you for the pic !! Have a great day !!
Tom
Old 04-03-2012, 08:38 AM   #24
shawn01520
I had the same problem with my Brothers Repops. I decided that since I will be towing with mine that I would get bigger better mirrors. I went to AutoZone and bought 2 1995 F150 Style mirrors. I like the look and there is plenty of adjustment, plus they are cheap as hell. The mounting point will need to be modified a little but they will work a lot better than the stockers. I have the new in the box set of Brothers Sport mirrors if someone wants them? Make me a reasonable offer.
shawn01520 is offline   Reply With Quote
Old 02-20-2013, 08:09 AM   #25
29od1
Old thread, but I added the a pic from Bruce's truck build on mounting locations.
Also, you only need to grind the edge of the lip (closest to the door) on the RH side mirror so it can rotate further inward.
