Old 11-28-2005, 01:34 PM   #1
va_tlc
va_tlc's Avatar
transfer swap question
first off hello everyone, i just joined very nice site here, ok my question is, i just bought a 3/4 ton running gear with a 4 speed, and im gonna put the body from my 72 over onto it,and its a 307 witha t 350 auto trans, what would i need to do so i can use the auto , can i use the trans case on the auto trans?,, ohh and the 72 body is a 2wd for now,thanks for any help here guys,,, im gonna try and get some pics, before and after , i see yall guys have some nice stuff,
va_tlc is offline   Reply With Quote
Old 11-28-2005, 03:02 PM   #2
Yukon Jack
Yukon Jack's Avatar
Re: transfer swap question
If you want to use a different transmission, you will need to find the correct transfer case adapter. Shouldn't be too hard to find that transfer case. I have only dealt with 4wd manaul transmissions and I know they normally have a different output than the 2wd transmissions. I will let someone else discuss what you would have to do to mate the adapter to your t350.
Oh, welcome to the board!
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-28-2005, 04:02 PM   #3
va_tlc
va_tlc's Avatar
thanks yukon jack, i do belive theres something else i do need ill wait around im sure some one on here knows what i need, im still thinking of leaving the 4 speed, but if i do go with the auto, i wont have to put the clutch pedals into the the body im putting on, so i guess its work both ways, , im hunting some of my old pictures from of the chevys iv had and sold , but this ones gonna be nice a 72 short bed 3/4 ton 4x4, dont see them everyday,
Old 11-29-2005, 10:01 AM   #4
CUSTOM/10
CUSTOM/10's Avatar
The 4spd & auto tranfers cases have different spine counts, so if you want to use the same TC you would also have to change the TC input shaft. ( That maybe tuff to find used & expensive new ) You could also buy an adapter from Advanced Adapters, but this also would be pricey. If you really want to go with an auto it would be best to find a TC that's already set-up for an auto. Make sure it's from a T350 because the spline count is different again for the T400's. ( This info is for a np205 TC ) I don't know about other TC's.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 11-29-2005, 10:05 AM   #5
FormerMember
4x4 TH350 is a 27 spline out put.
4x4 TH400 is 32 spline
Some 2wd TH400's are 32 spline as well, but they have different length output shafts.
FormerMember is offline   Reply With Quote
Old 11-29-2005, 03:51 PM   #6
va_tlc
va_tlc's Avatar
thanks guys i belive thats the answer i needed, iv found a wreck newer truck that i think i can get the motor and auto and transfer out out , i belive that will be the cheapeast way, or use the 4 speed that came in the frame, but the guy i bought it from didnt know anything about it, wether it was good or not, the shifter does work thou, so maybe ill get lucky, thanks again for the info, im sure ill have plenty more questions for yall
Old 12-05-2005, 03:38 AM   #7
454_72_4X4
454_72_4X4's Avatar
You would need to change the output shaft of the TH350 to a 4x4 version, (shorter), and also change the input of the transfer case, (as mentioned above) to the th350 27 spline size. Manual trans spline count is 10 spline for the trans and transfer case.
You're also going to need a th350 tranfer case adapter, (the part that goes in between the trans and the transfer case).
Do you know which transfer case you have? NP205 or NP203?
Another thing is your 2wd cab. I THINK you'll need to get a high hump floor pan for it. (Or that might be just for manual trans 4 speed trucks?) There's others here that know more about that than I do. Maybe they'll chime in.
Last but not least, Welcome to the board!
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
