Old 11-28-2005, 03:29 PM   #1
ed455
Captain Ed
400 block - prepped and 434 assembly
NICE 400 block 511 casting (4 bolt) bored and honed for forged pistons. Align bored, square decked and set with pistons .015 in the hole. Deck is plugged for strength but steam holes are NOT plugged. The lifter valley has been tapped for crankcase breathers. Brass freeze plugs. All oil plugs tapped and plugged. The pan rails and bottom of the bore are clearanced for up to 3.875 stroke with H-beams. Painted with three coats of black. This block is the nicest I've seen in a long time and is completely prepped and cleaned absolutely ready for assembly. I'm only selling to go with a dart block.This block had 70K miles on it. $650 (machine work alone cost more than that)
434 rotating assembly - cola crank, JE pistons, 6" Eagle H-beams (cam clearanced), Speed pro rings and clevite bearings. All new and internally balanced ready to install. $1600 OBO (cost $2500 originally).
If you ain't bleedin', you ain't workin'!
1999 C3500 LS 7.4L
ed455 is offline   Reply With Quote
