The LuvShack Garage
I have this really nice set of Green sunvisors I want to sell,
but I can't get the damn things off, the only thing holding them on it the Phillips head screw, and the whole thing is turning when I try to unscrew it, any tips, tricks, ideas ![]()
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 11-28-2005 at 06:25 PM. |
Re: Removing Sunvisors
let me know when you are ready to sell them
If your talking about the visor brackets on a blazer, the backing spring nut is probably rusted off and turning with the screw. If you try and pry on the bracket while turning, you might get lucky--otherwise you will probably have to drill out/off the head of the screw.
#4 | |
The LuvShack Garage
I tried the pry with force while using a screwdriver method, didn't get lucky ![]() Next step will be drilling unless someone adds another tip / trick to the list.
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 11-28-2005 at 10:43 PM. |
I just need the brackets anyway so the small tears dont mater
Well if you don't get them off I have a pair that I need to get rid of. I haven't looked at them close enough to know what kind of condition they are in.
No clue how to get them out if the nuts came loose.
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
Blazer visors have a bolt that goes through them to hold the top on????
Marysville, WA (Dan72cst@hotmail.com) 72 4wd Blazer CST 350/350 72 4wd Chevy LWB 350/350 68 2wd Chevy LWB 327/400 |
I've had the same issue...
My cure/fix was to use an air gun. By "blipping" the trigger the start up revolutions from the gun eventually manage to loosen the nut/turn out the bolt. Worked for me anyway, good luck. Try soaking your nuts for awhile with PB Blaster or similar... ![]() ![]() Last edited by vtblazer; 11-29-2005 at 01:08 PM. |
You said soak your nuts he he he, shut up Beavis!!
#10 | |
The LuvShack Garage
