Old 11-29-2005, 03:30 PM   #1
shifty
Questionable
shifty's Avatar
Need high hump help
Seems to be a popular topic lately.
I'm going to be cutting out my low hump and finishing the bolt-up for my tranny this week. I was curious if anyone could give some pictures of:
1) A stock high hump floor that's bolted in.
2) A stock high hump floor with the hump removed.
3) Maybe give a picture showing how much overlap there is.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 11-29-2005, 03:34 PM   #2
shifty
Questionable
shifty's Avatar
Re: Need high hump help
PS - I already have the high hump replacement from an AT truck.
Old 11-29-2005, 03:52 PM   #3
redhead69
fugedaboutit
redhead69's Avatar
This is all I have right now but could snap a couple shots when I get home from work..
http://i7.photobucket.com/albums/y25...nandrocker.jpg
http://i7.photobucket.com/albums/y25...ad69/dash3.jpg
Currently truckless
redhead69 is offline   Reply With Quote
Old 11-29-2005, 06:21 PM   #4
JameslovesJammie
God Bless Mr. T
JameslovesJammie's Avatar
Here's a pic of my high hump. It's in perfect shape and is shiny and rust free. I just wish I could say the same thing for the rest of my floor!
Like a midget at a urinal...sometimes you must stay on your toes.
JameslovesJammie is offline   Reply With Quote
Old 11-29-2005, 06:33 PM   #5
shifty
Questionable
shifty's Avatar
James - thanks - that's a great picture (i'll stick it to my post). redhead - thanks to you also, I'd like a closer shot of the hump when its off if you got one. I'm open to seeing more pictures if anyone has em.
Thanks a ton
Old 11-29-2005, 10:54 PM   #6
Bob Moore
Shifty - If you have your high hump piece already, position it in place-side to side even and in the forward location. Use a felt permenant marker to outline the edges and the holes. Remove the high hump and sketch out the inside edge. Use slip on nuts(j-nuts or something like that - Lowes carries them) to fasten the high hump down. Cut the hole smaller at first and then enlarge it as needed.
Good luck - Bob
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 11-30-2005, 12:43 AM   #7
Striker169
Car O'Holic
Striker169's Avatar
quck question for redhead69 do the new floor pieces come with the studs for the gas pedel and the holes for the high/low switch?
Striker169 is offline   Reply With Quote
Old 11-30-2005, 01:41 AM   #8
redhead69
fugedaboutit
redhead69's Avatar
No studs for the pedal. There is an indention for the high/low switch, just have to use some self tapping screws or pre-drill.. havent got that far yet though
Currently truckless
Old 11-30-2005, 10:28 AM   #9
Yukon Jack
Yukon Jack's Avatar
Shifty - here are a bunch of pics I took when I was swapping my high hump for a low hump. I have a body lift that allowed me to do the swap to the low hump in my 69 K20. I may have posted some of these before but I figure more is better than less.
Here are a few pics of the stock high hump
Here is the floor with the hump removed to see how much overlap there is
Ignore the wierd shifter extension - that has gone away
Here are a couple pics of the low hump installed
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 11-30-2005, 10:37 AM   #10
shifty
Questionable
shifty's Avatar
Bob - thanks for the advice.
Yukon - thanks for the pictures. Based on the pictures, looks like your low hump was welded to the floor originally? Perfect - this is my exact setup (think your pics are backwards in progression though ). Ddi you curl the floor metal over after you cut the hole? It's got a nice little bevelled look to the edge of the hole...If so, how'd you do that?
Old 11-30-2005, 11:34 AM   #11
Yukon Jack
Yukon Jack's Avatar
The low hump came from a boardmember who had a junk cab. He used a torch probably to cut it out. I have never worked with a low hump cab before so I don't know if the low hump is stamped from the floor or is welded in normally. I think what I did is the reverse of what you are doing. I had a high hump cab in my 4wd and I changed it to a low hump - I did this so I wouldn't have to modify my transfer case shifter due to my body lift. I didn't have to modify my floor at all - that is the way a stock high hump floor is - at least in a 4wd. Hope this answers your questions.
Old 11-30-2005, 12:22 PM   #12
shifty
Questionable
shifty's Avatar
Yeah, that answered everything!
I'm not sure how much of a lip I'll have on the floor. Should be pretty interesting weekend getting all this done.
