Newby question - Window seal?
The driver's side window seal on my 83 K20 is deteriorated, and I don't want rain and snow dripping down into the door and causing rust.
How do I remove and replace this rubber seal? Do I have to take the door apart? Where can I find replacement seals? Thank you, Bud
Current GM toys: 1983 Chevrolet K20 4x4, 2004.5 Chevrolet 2500HD LT Duramax 4x4 |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Re: Newby question - Window seal?
The seal that run around the glass? You have to remove the glass from the channel to get it in there.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
I'm probably not describing it right, but it is the rubber seal that rests against the bottom of the outside of the driver's window. It looks like the previous owner drove around with the window down, resting his arm on the door and the rubber wore out.
Sb 400 club
ahhh yes i need a new one too. with the window dow you can get them off they use little clips. The replacement is avalible from chevy, lmc truck.com , and chevy duty.com, and jc whitney.com. good luck yeha mine needs that as well as all the vent window seals replaced
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out Last edited by 84 400; 11-29-2005 at 08:57 PM. |
Thanks for the sources.
My vent windows whistled badly, so I used clear silicone caulk around the outside to seal that up. I plan on cutting through the silicone with a razor blade to allow use of the vent come summer.
I sell all those seals also. I just haven't added them to the catalog yet. Another source is the Dealership.
ureckmefixit2@cox.net
It's called a belt molding/seal get it a the dealer
That's U RECK ME FIX it 2 74 Chevy Short Bed 355ci Sportsman II 64cc Angle Plug Crower Custom Grind .462in .486ex Dyno Test 422hp @ 5600 And it's got a Holley 3.73 Gears 12 Bolt 3.73 w/Posi 700R4 Going In I'm a Body Man So There! That's why it's not painted |
