I started tonight to dissassemble my 72 parts truck YEA ! What I thought might be a fix the cracked frame project ended up in a Hey where is the frame ,extremely rusted from the cab back WOW never seen any thing so bad.So it has turned into strip all good usable parts now.At least now I will get power disk brakes in my 70 !!And maybe the turbo 350 auto instead of my 4 speed.When did they change the transfer lever from the left side to the right side of the hump ? it also looks to be a NP 205 transfer case. Also hoping it is a not a 4:11 rear so I can swap mine to a lesser ratio.I also end up with later model white spoke factory wheels and centercaps.COOL!
------------------ 1970 K-10 292 Longbed stepside powersteering but manual brakes!Factory step bumper,Deluxe gauges no Tach 4 speed manual 1 out of 464 made with protectoplate intact.Its basic for a farm truck
Where Am I ? How did I get Here ? ![]() 1970 K-10 292 Longbed stepside (now a stakerack)powersteering ,Factory step bumper,Tow Hooks,Deluxe gauges Tach & Throttle, 4 speed manual 1 out of 464 made with protectoplate intact . |
#2 | |
Bloo
i duno about 72 but my 71 4x4 has it on the right side
ASE Master Certified-GM Trained-Mechanic 1968 Chevy C30 157" WB Wrecker 1969 Chevy CST/10 SWB 1971 Chevy Custom/10 (first truck) 350, NV3500 5 speed 1971 Chevy K20 Custom Camper 4x4 350 TBI, SM465/NP205 1974 Chevy Custom Deluxe/10 1979 Chevy Custom Deluxe K10 farm truck beater 1989 Chevy K2500 Quote:
On my 70 its on the left,real handy there too I dont have to reach around the shifter!Is your 71 auto or manual trans ?
#4 | |
Bloo
1971 Chevrolet 3/4 ton 4x4 lwb fleetside, 355 SB, flat tops, headers, 4 barrel q-jet, HEI, SM465 4 speed manual, NP205 t-case, eaton rear, dana 44 front, 4:10 gears
^complete specs i can think of at this time
Hmm thats wierd my 70 1/2 ton 4x4 is a NP 205 too with a 4 speed. I will have to compare the two when I take the 72 apart to see what the difference is.
#6 | |
Bloo
hmm...only thing i can figure out is maybe the shape of your shifter, like maybe it is bent to come over farther
Yes It must to come through the floor to the left of the shifter. will look further into this .
Resident Curmudgeon
![]() Join Date: Dec 1999
If your 72 is a 1/2 ton 350/th350 combo it would have had 3:07 gears from the factory unless optioned with 3:73's. If it's a 3/4 ton, 4:11's were only option. If it's a 307, the standard gears were 3:73 and 4:56 for 1/2 and 3/4 tons.
On the NP205 shifter, the 70's had it coming up dead center in the hump, and the lever is bent towards the driver. 71/72, the lever comes up thru on RH side of hump and is basically straight. 71/72's also had the shift pattern on the knob whereas 70's don't. ------------------ Jeff Jesseman Cheyenne Parts Northeast Franconia, NH 67 Chevy SWB Fleetside 70 GMC Burb 1/2 ton 2wd 72 Chevy Burb 3/4 ton 4x4 Parts bought and sold
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Its a 250 six with a TH-350,I see there is only a 3.07 or a 3.73 ratio's in a 4x4 in 72.I believe I will swap my 4.11 for what ever it is ,where is the tag on it anyway ?I have been disassembling for two nights now so far and bagging small parts and labeling them. You were right on the extreme rust on the frame ,it had been repaired under the pass door and way back by the spring mount nothing behind the cab is left.
