11-30-2005, 01:12 AM | #1 |
rear brake bulb.......
i have installed new led 1157 bulbs, and now only one light is on,it is super bright.buit only one lights up when lights are on, both come when brake is pressed, both are on when using flashers,,,,,,,, but only one is lit when lights are on.......i am so confuuuuusssseeeddd ..help, explain, tell me how to fix it,,,,do i need more parts or what!!!!
TIM '71 CUSTOM C-10 torch red ,350 roller GM crate,3.73 GEARS, REAR 4"DROP SPRING, FRONT 2.5" DROP SPINDLE-1.5"lower spring, FRONT=17x8(4.5bs) W/265-60-17, BACK=17x9.5 (5bs)W/285-60-17, Vintage Air Sure Fit AC------NEVER ENDING PROJECT!! |
11-30-2005, 07:47 AM | #2 | |||
Union Electrician
Re: rear brake bulb.......
I believe you may have the bulb in wrong, pull the problem bulb out and make sure you didn't get it in there wrong? look at the tabs on the bulb to make sure you are getting it in there correctly.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
11-30-2005, 08:19 AM | #3 |
Bulb is probably bad. Tail lights function on one fillament and the brake/turnsignal on the other. Try it on the side that works. That should confirm it!
Smitty '71 Short Fleetside Spring Valley, Ca. |
11-30-2005, 08:41 AM | #4 |
what they said
