Old 12-02-2005, 09:11 PM   #1
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Did you have to cut?????
I am installing some headders tonight and they are crashing into the motor mounts should I just cut the mount to clear???? I f you have ran into this problem what did you do to claerance it??? btw its a 454 on 350 stands 2wd 1/2ton
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-02-2005, 09:28 PM   #2
chevy_fatman
Where's my beer?
chevy_fatman's Avatar
Re: Did you have to cut?????
What headers did you use? I wouldn't cut any motor mounts, especially being a BB, lots of torque there.
Paul
How do you make the invisible, visible?.........You take it away.
chevy_fatman is offline   Reply With Quote
Old 12-02-2005, 09:40 PM   #3
clay68c10
clay68c10's Avatar
The BB stands have an extra bend to clear the original manifolds. Maybe the SB stands are too tall? I had Hooker comps on my old 396 and they cleared the BB stands by about 1/2" in that bent area.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline   Reply With Quote
Old 12-02-2005, 09:40 PM   #4
qksilver
My bb mounts have a clearance curve right under where the mounts fit. Small block mounts don't....
i am not sure what company has them but there are tubular aftermarket mounts that are around 120 with mounts and they are suposed to clear just about anything.
Steve
qksilver is offline   Reply With Quote
Old 12-02-2005, 09:48 PM   #5
chuck1960
Junior Member
chuck1960's Avatar
we put a 454 in a 70 model with sb stands and the hedders hit the stands. had to change to bb stands and then everything fit ok
chuck1960 is offline   Reply With Quote
Old 12-02-2005, 09:57 PM   #6
ratrod67
ratrod67's Avatar
Yep, you need BBC stands. I tried it on sbc stands and it didn't clear either. I went through 3 sets of headers even with the right BBC stands before I found a set that didn't hit either the frame, oilpan or motor mounts. 3rd set was the charm.
ratrod67 is offline   Reply With Quote
Old 12-02-2005, 09:59 PM   #7
FRENCHBLUE72
PROJECT 7DEUCE
Here are a few pics...... Can anybody tell me what year these motor mounts are for?? Btw they are headman headders..
MEMBER #6377
Project "7DEUCE"
Old 12-02-2005, 10:34 PM   #8
71Dragtruck
71Dragtruck's Avatar
What they said, mine didn't work either had to get BB stands, the ones that you have off look like the ones you need, with the dip in them.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 12-02-2005, 10:39 PM   #9
kwmech
When you install the correct stands the engine will be pushed back 1''. If you don't want to do that you will be drilling
Old 12-02-2005, 10:41 PM   #10
71Dragtruck
I just had to notch the big hole a bit for mine, then used big thick washers from balancer bolts, you can also make some out of thick flat iron.
Sponsored by:
Hard Candy Customs
Old 12-02-2005, 10:57 PM   #11
ratrod67
ratrod67's Avatar
Those your holding look like 68-71 mounts. The 72 mounts look like this:
Old 12-02-2005, 11:09 PM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
the stand you were holding is the 68 - 71, the ones mounted are small block and then there's the 72 style ratrod posted.
Old 12-02-2005, 11:24 PM   #13
FRENCHBLUE72
PROJECT 7DEUCE
68-71 Those Are The Ones That Have The Rubber Part That Is Hard To Find Correct????
MEMBER #6377
Project "7DEUCE"
Old 12-02-2005, 11:29 PM   #14
ratrod67
ratrod67's Avatar
Check this FAQ thread out. Lots of good info.
http://67-72chevytrucks.com/vboard/s...d.php?t=122645
Old 12-02-2005, 11:51 PM   #15
FRENCHBLUE72
PROJECT 7DEUCE
Thanks rat rod it looks like I have all the parts to make it work just need the harmonic ballancer washers.. Thanks guys..
MEMBER #6377
Project "7DEUCE"
