Old 12-03-2005, 02:35 PM   #1
chevyboy55
chevyboy55's Avatar
Steering column slop
The gear selector on the column is rather sloppy(kinda hard to tell what gear your in) What all is involved in fixing it? Thanks, Mike
chevyboy55 is offline   Reply With Quote
Old 12-03-2005, 05:25 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Steering column slop
Need specifics.Is it a 3 speed auto or what?
First suggestion is to check the bushings on the shift levers at the tranny for either type.I'm sure someone can give you a better idea how to fix it but you need to let them know what you're trying to fix.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 12-03-2005, 07:03 PM   #3
chevyboy55
chevyboy55's Avatar
It is an auto, tilt. It is just loose & sloppy
Old 12-03-2005, 07:14 PM   #4
Aquivarious
Aquivarious's Avatar
I just baught my truck not too long ago and i have the same problem. Id say check the gear select linkage and check if its good, and if the connections aren't loose on both ends, since im replacing my tranny and getting a shift kit im not worried about mine, but id explore that option if i were you.
D
'71 Chevy C-10 SWB (Project)
'04 Mazda RX-8 (F*** around Car)
'85 Chevy C-20 (Former Project)
Currently Serving In IRAQ. (Man it sucks over here..)
Aquivarious is offline   Reply With Quote
Old 12-03-2005, 08:56 PM   #5
Alan Potter
I've heard there is some sort of nylon bushing at the base of the shift lever that wears out over time. Maybe your problem?? Maybe not.
'12 Silverado Crew Cab 4x4
'05 Silverado SWB
'67 Chevrolet CST 2wd
'49 Willys Jeepster
Alan Potter is offline   Reply With Quote
