Please help decode my motor
Ok, here is what i could barely read
VC417FLF underneath, and thi sis barely readable and I even sanded it IEJ52151A I was told it was a 350, ok if so, what year, etc etc thanks sooooooooooo much
http://i30.photobucket.com/albums/c3...c/IM001769.jpg |
#2 | |
Re: Please help decode my motor
Check out the flf part real good because I dont have anything like that. I have a ton that are one letter off of it in many combinations. What year do you think it might be? Don |
the FLF part is correct. Just the numbers and letters below I can barely read. No idea what year it is,thanks for the help
Surly*Speed*Demon
V=Flint Engine Plant
04= April 17=17th As far as the FLF goes there is no such code . It may be a TLF or a BLF TLF= 1978 400c.i. BLF= 1990 305c.i. Oter possibilities are: FLH FLJ FLK FLL FLK FLM FLR FLS FLW These are all 85' 350 codes You might want to go by the casting number on the rear of the block. Last edited by RSTYCVY; 12-05-2005 at 07:17 PM. |
which side on the block,pass or dr side,near bellhousing??? I will get it,is it hard to read or get at???
Surly*Speed*Demon
I would check the driverside first then the passengerside. It is difficult to access. A mirror helps. If you can clean the area off, a piece of clay to make an impressoin helps too.
ok I will check, let u know tonight what and if i find anything, thanks...i am
No No
Dont get your hopes up. It's not a 400 most likely not a 350 either, it's a moslt likely a BLF 305. is your harmonic damper (ballancer) 8in or 6in?
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler |
ok this is what I got from the drivers rear. "4010207"
The only nuber that is questionable is 401?207, maybe an 8,2< Not sure,best guess was a 0. Very hard to see back there............Maybe I was misled when I bought this truck. Was told it was a 350
Insert Witty Text Here
My '86 305 actually has a big "305" cast into the block near the front in numbers about 3/4 in tall. You can see it from underneath, I think on the driver's side. You might see if yours has that.
Slonaker |
just checked on another site.
1980-85 year 14010207 block number 350 cu - - 4 bolt main truck thanks for the help
weird thing is....dipstick on pass side, and I double checld the numbers 3 times, its a 350, 4 bolt main. truck motor, it may actually be the orig motor. I was told its 60 over,roller rockers,400hp. I believe it cause this truck is fast.
#13 | |
No No
Yea, but Ive had 305's that were vituraly stock that people would crap thier pants driving. Which site did you get the casting numbers from, www.mortec.com/ ? 1401207's can come in either 2 or 4 bolt flavors. ![]()
1976 Custom Deluxe SWB Med FMB.3/4 Drop. Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out. 1997 K1500 ext cab 5.7 stock except muffler Last edited by SSC's76; 12-06-2005 at 12:37 PM. |
#14 | |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com Last edited by Captkaos; 12-06-2005 at 09:08 PM. |
#15 | |
No No
True. My 86 came with a 4.3L from the factory. ![]()
#16 |
Here is my VIN, decode away!!!!
2GTCC14D3B1544071
#17 |
my motor has a 5.7 raised numbers on the passenger side behind the head facing up just before the tranny and block join together maybe that will help also b/c you still sound doughtfull sp?
square body trucks an addiction or an investment either way they consume all my extra time and money |
#18 |
Here ya go... (typo'd on the above, should have said 8th not 5th, I corrected it)
2 - Canada GT - GMC C - 4001-5000 Hydraulic C - 2 Wheel Drive 1981-1986 1 - 1/2 Ton 4 - two door cab D - 250 Inline 6 cyl 3 - Check digit B - 1981 xxxxxxx - production number
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
#19 |
what does check digit mean??? Was it an automatic or stick?
#20 | |
No idea on the trans. That would be listed in the Options sheet in the glovebox.
